Amsoil.
710-oil-614
Cal
2025 Hybrid AWD Lariat
I have yet to meet an engine that it is worth it.
Mobil1 is damn good, and a lot cheaper than AMSOil or Royal Purple.
5 qts of Mobil1 5w30 Full Syn is $29.47 after tax at my local Walmart.
I buy RP in 5 gal (20 qt) containers. The most recent container cost me $129.33 after tax - or roughly $25.87 per 5 qts.
So for me - RP is actually cheaper and a superior oil.
MavJet
Todd
Latrobe, PA
2024 Maverick Lariat Tremor
Being a Jet Technician for more than 35 years and growing up working at a Ford Dealer. Oil changes are the most important thing for your vehicle. I've always use OEM Motorcraft oil filters and The correct specification of oil plus the correct Ford recommended SAE weight. I prefer FULL Synthetic. I change it every 5K miles. I've never had A ford engine issue. My first Ford at age 16.
Maverick Grabber
Indiana
2015 Chrysler 200, 2022 Maverick XLT Red
A company called Blackstone is pretty famous for being one of the best. They are $35 for the OA but most people opt for the added TBN, so $45. They will send you the sample kit for free and you pay for the testing. It's all really simple. Even if you took your vehicle to the dealer to get your oil changed you could ask them to grab a sample for you and I'm sure they'd have no problem doing it and are likely used to it (or most do it themselves as well). Here is the site:
https://www.blackstone-labs.com/
Just hit the "get a free test kit" button and go from there (y)
It's a very popular thing now days. Instead of just guessing how long your oil change intervals should be, this is the best way to know if you are stretching too far or not far enough.
I pull the dip stick look at the color, smell the oil and rub it between my fingers, for the cost of a test you could do 2 extra oil changes a year
Johnny maverick
Nh
22 mav 16 superduty 89 xr7 sc 5spd 84 gt turbo
I drove it nice for the first month. I did my first oil change at the dealership at 2500. Then used the oil minder for oil changes. I use Mobil one a 910 Motorcraft filter from Walmart. 29.97 and 8.44 for oil and filter. I did notice when I did my own oil change only half my skid plate bolts were reinstalled at the dealership. I justvdod my 4th oil chang and I have 23k. No issues. Using any quality oils and filters is never an overkill. Go for it.
Maverick Grabber
Indiana
2 oil changes for $45?
Obvious troll is obvious.
Yeah if you only do one oil change a year, 45 x each oil change is at least 90, I do 3 minimum that is 45 x 3, can you do math?
Snox801
Levi
Spring Lake Michigan
Amsoil is top notch stuff. In fact that’s all I run in my ecoboost. Especially anything direct injected. They are able to pass the wear tests with a seriously high fuel content.
So it’s a small sample size but I have ran my dad’s 3.5 ecoboost at 15k change intervals on it. Truck was a work truck. Made 390k miles and still ran when he sold it. My 15 3.5 I did it every time the oil monitor told me to. I had 374k on it when it got totaled ran perfect. That truck was highly tuned and was 500whp with meth. It’s still lasted through all my drag racing trailer towing, and work. My wife’s 2.0 edge had been on amsoil since 500 miles. It’s also been tuned for e30 fuel since first week I owned it. It currently sits at 189k.
It seems to be a very good oil. To me worth the price because I haul some serious heavy stuff and being tuned for more boost I work them very hard. It’s not let me down yet.
Montana
Show me what oil and filter you are getting for $45. And yes, I can do math. Your original comment said 2 oil changes for $45 and now you are staying each? Can YOU do math or recall what YOU stated?
Look dude, we get it. You don't want to pay for a test and you think you know everything.
Cool story bro. Check the attitude at the door. You are not the first grumpy old man to come into forums like these and you won't be the last one to eventually catch a ban for it. Grow up and quit trolling.
Do your "smell test" and move on. I gave someone an option for real data. Why are you here? (It's rhetorical)
DavidLs
Texas `
Ranger/23 and 24 Mave hybrids
I guess I am in trouble. I use the low end Walmart pit crew or the 0Reillys cheapest special they have that is out there. I thought oil was only put out by two major companies and repackage or labeled into the Big Name brands. The 05 Ranger hasn't had a high price oil change.( I do Change her oil every 12 months weather she needs it or not)
realshelby
Houston
1969 GT 500, 1965 Mustang GT,
Blackstone Labs for oil analysis tests. About $40. They will mail you a free sample kit.
Any opinions that do not have an oil analysis attached are just opinions.
I fully believe you can go 250,000 miles with 25K oil changes...with any good oil. Certain vehicles are better set up to do that ( like larger oil capacities). But I will be doing oil analysis occasionally to PROVE the engine oil is holding up.
From what I see in oil analysis testing, there is almost no difference in so called high end oils ( like Amsoil and others) compared to Mobil One for instance. This is based on measurement of wear particles from samples of the same engines over time.
There is NOTHING wrong with running Amsoil, Liquid Moly, etc. They just cost more. Money you won't get back compared to what you pay for easily available full synthetics like Mobil One, Castrol Edge, Pennzoil, etc. Oil related wear or failure is not why most cars end up in the junk yard...........
todd92
Todd
So many nonsensical opinions. Amsoil is a decent product. Wildly overpriced. Motorcraft oil filters are decent, nothing special, at least inexpensive.
I stock up on Pennzoil Platinum or Mobil 1 whenever there are rebates. The effective cost ends up being $3/qt when purchased in 5 quart jugs at Walmart. Oil filters, whether Motorcraft or SuperTech of Purolator are $6. So yes a quality oil and filter change is $24 if you don't like throwing money away.
There's no need for break-in oil changes or 5000 mile OCI or whatever other schedule you want to make up. Full synthetics don't need that nonsense. But do whatever you want for 'peace of mind'. Just spare us the 'you must' preaching.
Decayed
yes
a car
It can easily be done even with full synthetic. Walmart super tech full syn 5w 30 is $16.50 for a 5 qt bottle right now. Add in the cost of a filter and you are at or actually under $45 if you do it yourself. But you have to save the labor costs by doing it yourself.
We are at an unusual place with motor oils - the cheap house brand full synthetics from walmart, amazon or costco meet the ILSAC 6 spec and are worlds better than the best dinosaur oils of the 1980's and 90's. The base oils are better, the additive packages are better and you really can't go wrong with them. But people still think in terms of 90's oils because that's what their experience tells them.
Maverick Grabber
Indiana
You posted, Get your oil analysis done regularly and then you can choose your interval. For the first couple changes, do 3-4k and send in the oil analysis each time rhetorical) that adds 45$ to every oil change, my results below show I can do an extra oil change for every 1 that you do.
OK little petey, didn't mean to hurt your fragile ego. Enlighten us on what you do with the data you get back, do you change engines? Bearings wear in, piston rings try to wear on cylinders, other than pretending you are some elite gearhead who bought an entry level pick-up. What do you get besides feeling you are better than anyone?
Mobil 1
Mobil 1 Extended Performance Full Synthetic Motor Oil 5W-30
(4.8)4.8 stars out of 931 reviews931 reviews
Now $29.97
You save $12.02
was $41.99$41.99
2.1 ¢/fl oz
Mobil 1
Mobil 1 Extended Performance High Mileage Full Synthetic Motor Oil 5W-30, 5 Quart
(4.9)4.9 stars out of 575 reviews575 reviews
$29.97
You save $0.00
18.7 ¢/fl oz
That leaves 15$ for a filter
Montana
@MaverickGrabber
I find it alarming that you don't see the benefit in oil samples. Never said anyone HAD to do them, but acting like they are not beneficial or that being able to actually understand the data isn't helpful is just idiotic. Acting like a smell test and a guesstimate on intervals is "smart" and condescendingly ignoring data from analysis information is next level boomerisms. So yea, if understanding the data makes me an elite gear head, I'm cool with it. Better than whatever you are coming in a thread acting like some oil whisperer just because you don't want to pay for samples. Do you then... just stfu about it.
At least I don't act like I can smell it, taste it, and rub it between my fingers for any actual information like it's some ancient wisdom. If you don't want to pay for samples - don't. Continue on your guesstimate adventures and enjoy your process. I'd like to know the contents of what is running through my engine and if it's safe to increase intervals - not just guess and think I know better.
So... my problem was never with your stance or your opinion - it was your mannerisms. Grow up. And your math STILL doesn't check out. Thanks for sharing cheap oil and it's a great option! But you claimed TWO oil changes for the cost of one sample - and clearly that's not the case. Where is this free 2nd oil change coming from if the cost is $45 per?
"elitist" mathematician out.
*Disclaimer - don't start none won't be none. There are 1,000 different ways you could have tactfully came into this thread with your opinion, but you chose the wrong way. There is no justification you are going to regurgitate for your grumpy attitude, oh wise oil whisperer. Add another future banned member to the ignore list.
Who said this? Anywhere in this thread?
Oil threads are always this way, especially the ones who believe they need Amsoil to make a vehicle great again... But I haven't seen anyone saying that someone else needs to do anything yet. Suggestions were made on how to approach an oil analysis. That's all. If you read their disclaimers that's exactly what they want to get a base.
