Ambient Air Sensor
Bdallas
Bud
24 eco boost, outside temp read up to 50 degrees off. Dealer is on 5th attempt to fix. Any thoughts?
Ozarkbeard
Did they replace the thermometer at the front of the vehicle?
Bdallas
Bud
They replaced a sensor up front, not sure what it's called. It required bumper removal. The last attemp was the heat/ air control module
"Bdallas" Bud,
Other than the the outside ambien air temperature showing 50° off.
Was it Above or Below ambient temp.?
Did you notice any other possible related problems?? Such as engine, climate control....???
Is the temperature always 50° off or does it happen sporadically?
There is a reason for the questions.
I just don't want to steer you towards a specific reply.
Only because I've seen this happen before in other systems, that support F and C.
Up to 50 F off. So not constant.
What was an actual reading though at some point?
And do you recall what the outdoor temp should have been at that point?
If you have truck - just get the current info:
Dash reading.
Actual outside.
Besides that - did they reset the calibration?
If Forscan Lite has it - I know their scanner does.
Ford Maverick Ambient Air Sensor Screenshot_2024-12-13-15-03-33
  • Like
Reactions: bgn
22_Mich_Mav
Mine did the same thing and dealer swapped out sensor under fender liner. Not only did it fix temp but my Mav started running better..bonus!
Ford Maverick Ambient Air Sensor IMG_0391
That's funny. I have a picture of my Buick Encore with that same temperature. The only thing is, it was actually 127° It was July in Death Valley.
Ford Maverick Ambient Air Sensor IMG20230716161524
24_bob
Oklahoma
2024 Hybrid Maverick Lariat 2022 Eco Maverick XLT
I had a similar experience. Try locating the connector behind the passenger side front wheel well. There's a connector mounted on the right side just behind the fabric wheel well cover.
Mine was full of water. Blow it out with compressed air and fill it with "bulb grease" to prevent future water intrusion affecting the temperature circuit.
In my case, I suspect the water was from undercarriage car wash and the adjustment holes I drilled for my fog lights. No issues since covering the holes with tape.
Already new sensor - same issue.
For me it was not the sensor. Its a harness connection behind the passenger wheel well. Its fairly simple to get to it and check.
Yes I caught that.
I was informing you the OP already got a new sensor, so suggestion to check the plug in his case probably not worth the hassle.
22_Mich_Mav
That's funny. I have a picture of my Buick Encore with that same temperature. The only thing is, it was actually 127° I was July in Death Valley.
It was 10 degrees out when I took mine.
24_bob
Oklahoma
Yes I caught that.
The problem is water causing the signal to degrade inside the connector. The connector is separate from the sensor. In this case, the connector is inside the wheel well, about 3 feet from the actual sensor. I was surprised by the amount of water inside it and the green corrosion on the terminals. Sand paper, and a toothpick helped clean it up.
I thought the same thing when I had my issue, but hated the idea of the dealership taking apart the bumper for a sensor that was still sending a signal, albeit a wrong one.
Ahh - got it. True they may not have examined the wire side of connector, or just packed it full of di-electric grease.
FischAutoTechGarten
Peter
Interesting, becuase mine will read completely off sometimes as well.
