Airbag cover is splitting
Phimosis
Larry
Santa Clarita, CA
I have a ‘23 lariat with 23k miles. I am about to go to the dealer for a second time for this issue. The steering wheel airbag cover is splitting along the break line. This is the same exact spot the previous one split at 10k miles. Anyone having a similar issue?
That’s not a split though. That is surface abrasion. And it’s happening along that line because it sticks up higher than the surrounding area. I don’t have that problem because my steering wheel literally never gets touched there, other than the guys at the car wash doing an interior wipe down. That definitely looks like something has been drug across that surface numerous times to wear down the surface of the vinyl that much.
Doughou78
Doug
Houston
2023 Maverick Lariat Hybrid
It is not a surface abrasion. It is split along the breaking point for the cover. The horn never gets used and that spot is almost never touched. It is a defect.
Phimosis
Larry
Santa Clarita, CA
Ford Maverick Airbag cover is splitting IMG_2102
The image you uploaded shows discoloration, but it does not show separation of the upper and lower half of the material, which would be splitting. Feel free to submit higher quality images to validate your complaint.
jonshep
SW Oklahoma
File a complaint with the Feds. Probably result in another monster airbag recall.
Doughou78
Doug
Houston
Doughou78
Doug
Houston
it is not a discoloration. The upper half is starting to separate and pull back from the lower half. AGAIN, this is the second time this has happened. The first time the cover eventually split and was replaced under warranty. I was simply posting to see if others are having a similar problem.
I just hit 10k and mine is doing the same thing ,I just noticed it today. Coincidentally just had oil change done at the dealership yesterday.
Ford Maverick Airbag cover is splitting IMG_20250413_155251693
mcluvin
CR-V
I'd definitely ask them to take a look at the airbag. This could be something dangerous.
Absolutely, going to get it replaced under warranty, not something I want to mess around with. Definitely looks like it's separating.
Doughou78
Doug
Houston
I’ve had mine replaced once under warranty. This is the second time it’s splitting. I plan on taking it in for them to replace but I don’t want to have to do this every 15k miles.
I'm going to get it replaced ASAP, I am hoping this doesn't become a regular issue.
So, repair was done ,very quickly I might add, the truck was at the dealer less than 48 hrs. Looks as good as new. I will keep an eye on it, hopefully it doesn't become a reoccurring issue.
Ford Maverick Airbag cover is splitting IMG_20250425_161253306~2
Traian
Traian
Maverick XL
I have a '22 EB AWD and noticed the same thing on the airbag cover with mine, at first I thought is a scratch but looks more like a hairline crack in the plastic; I am the only driving it and barely using the horn. What's the deal here, can you buy that cover (part #?!) and replace it?
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
Doughou78
Doug
Houston
The cover is replaceable. The airbag is a separate piece. Mine was covered under warranty.
