Aeroskin and side reflectors installed
Scott
Upstate NY
2017 Ford Escape
Just installed the side reflectors and the Lund Aeroskin. Not too much trouble. The tape sealant enhancer left a weird blue mark on the paint where it wasn’t covered up by the skin, but rubbing alcohol got it off. STILL WAITING for BT Trims lettering. Says 2 day shipment it’s been over a week and no info and they don’t answer. Same with AAAPrintX for the cubby cell phone holder. Frustrating.
Ford Maverick Aeroskin and side reflectors installed IMG_2609
Johnkn
MD
When dry-fitting the deflector, It helps to install a line of blue painter's tape at the upper edge, left to right. That way the adhesion promoter doesn't get applied above the protector. Glad you got it off.
Good luck
Saratoga Maverick
Scott
Upstate NY
2017 Ford Escape
Good luck
Thanks
Yes I watched the video and used tape, just not continuous.
GreenLady
Jeannette
NE FL, NC, SC
Good luck
Thanks for the tip! I’m waiting on the dealer to get my next deflector. I plan on having them remove the other one and I will put the new one on. I know I can do a better job (after putting it on my 22)!
Here’s the dealer’s install followed by my 22 install.
Ford Maverick Aeroskin and side reflectors installed IMG_2087
Ford Maverick Aeroskin and side reflectors installed IMG_2088
Ford Maverick Aeroskin and side reflectors installed IMG_2053
Johnkn
MD
WOW!, I know you will take your time and do a perfect job...!
MaverRick
Rick
I am thinking about getting one for my Truck since Ford just gave me an award for 75000 points! Is this held on by Tape only?
Saratoga Maverick
Scott
Upstate NY
2017 Ford Escape
Yes double sided tape the length of the part, too and bottom.
Seems very secure
Watch the video from Lund.
MaverRick
Rick
Seems very secure
Yes, I like this better than the one that attaches via screws under the hood. Did you see the video where the guy tried to make adjustments while installing? He ended up breaking it then had to rip it off and buy another one!
GreenLady
Jeannette
NE FL, NC, SC
Yes, it is on with 3M tape and it is difficult to remove I understand. I thought it was easy to put on and did a much better job on my 22 than the dealer did on my 23.
I’m not sure I will install the replacement one because I’m not certain I like the look on the A51. You can see a sliver of blue on the leading edge of the hood no matter how good the install. I am considering replacing with PPF film instead.
MaverRick
Rick
I haven’t ordered it yet but I like the way it looks on yours! They just didn‘t put it on straight! From the video that I watched you only get one chance to do it right!
GreenLady
Jeannette
NE FL, NC, SC
You’ve got that right, only one chance! If you take your time it’s not difficult to get it on right.
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
Damn man! Was the installer drunk/high on that one? I've installed several of these. They are not that difficult. You peel and stick as you go...
GreenLady
Jeannette
NE FL, NC, SC
That’s why I’m doing it myself when the new one comes in. Any chance you know any tricks when removing the other one?
kkreit01
Korey
Olathe, KS
I haven't ever removed one. I would assume it's similar to removing badges. Heat it up a bit, and slide fishing line underneath. Dental floss may also work -- although breaks often.
MaverRick
Rick
Have you installed the new one yet? I am still debating whether or not to put one on my Truck. Please post some pics if you have! I need to make a decision before love bug season!!! Lol
