Adding wireless android auto/apple car play QQ.
Brandon
Bremerton WA
2022 Ford Maverick XL AWD
Hi,
I have a 22, and want to add wireless android auto/apple car play using one of the adapters from Amazon.
My question is does the adapter (usb-c) have to be plugged into the plug below the AC panel, or can it get power fron any outlet in thee vehicle to work?
Thanks!
Toddman45
St. Louis, MO
It needs to be plugged in to the USB port below the HVAC control in order to send the signal to the head unit and get power.
dlhort1955
Milwaukee
Maverick FX4
I have the Motorola MA-1. It has a cord about 6-8 inches long and it is plugged into the usb port below the usb-c port on the left side. The tape that was supplied by Motorola was not strong enough to hold the dongle there so I used some 3M tape. I did not try it in any of the other usb ports.
malicoreon
Pika
Eaton, OH
2024 Ford Maverick
kncklehedjed
Jarrett
Newfoundland and Labrador, Canada
2024 Ford Maverick XLT w/ FX4, 4k Tow, Lux
I had the Ottocast 2 in 1, but the cord would slip out around turns and freeze the display. Motorola seems to be the best.
I prefer to use a cord since it also charges your device while driving. Android Auto/Apple Car Play seem to drain the battery, kinda sucks after a long drive and your phones on 15%.
Jwaz68
Bradenton, FL
2023 XLT Tremor AWD, 2020 Nissan Kicks SV
Gullzway
OK
1968 Ford Mustang Fastback
AAWireless works with Android and iPhones. Also allows some developer settings to change screen resolution which enables things like the reporting on Google maps, and screen mirroring on Android.
Does need to be plugged into ports below the head unit.
I've had mine about a year with no issues.
AAWireless - Wireless Android Auto Dongle - Connects Automatically to Android Auto - Easy Plug and Play Setup - Free Companion App - Made in Europe https://a.co/d/04FXx25
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
I've had this one for a couple months and it seems to be working well. The cord is short but I'm fine with that because I stuck it right under the connection in the small storage area and you can hardly notice it. I had gotten a discount for $20 so it came out to about $30.
Bertram
Charles
Indianapolis, IN
2002 Ford Ranger, 2017 Transit Connect Wagon
Hi,
Thanks!
The two USB ports in the back will only charge. So you must use the ones in the front.
ofcbc
Crossville, AL, United States
2024 Maverick XLT
I have the Motorola 1A works adapter. I also have a usb-c adapter angle on it because I wanted a different angle to hide the unit's wire. It works in either plug. Currently, miner is plugged into the usb-c and it works exactly like it did plugged into the usb-a below it...
BromotoMaverick
Brandon
Bremerton WA
Thanks all for the responses, i might take the plate off and use some T connectors with a usbc plug to use an adapter. I did the wireless charger hack(seen on youtube) so trying to get away from cords.
A_streetkid_named_desire
Philadelphia
2023 Ford Maverick,1997 Mazda Miata, 2014 CR-V
I have been using the Autopro X. It is pricier than your standard dongle, but if you have a samsung for android auto, it also allows you to use DeX.
TwoTone
MD
Outback 3.6
How does it work with an Iphone?
Cancunbadlands
Cancun
Cancun
It's plugged in to the USB port below the HVAC control
Ford Maverick Adding wireless android auto/apple car play QQ. 20240409_071328
SP1966
Vegas
2024 Maverick XL Hybrid
Be aware, wireless Android Auto is a battery killer! I have an adapter, but quit using it for that reason.
