Apple car play
Gpp
Gil
Sanford nc
2022 ford maverick
What is the best way ,or port,to connect iphone to for car play?what all can it do.if there is a write up somewhere on it lead me to it and would appreciate it.i know the basics but seems to be a lot more it can do that I don’t know about.yep,the old man strikes again🤣
New2AZ
Scottsdale, AZ
2019 Civic EX Hatchback
I have USB-C to lightning (Apple OEM) cable and mine connects instantly and no interruptions. Though as we've learned, there's a glaring difference between the SYNC-3 and non_SYNC interfaces.
oljackfrost
Minnesota
I found this coiled usb cable on Amazon. I like it because it allows me to set up maps or music and then it stays out of the way.
Coiled USB-C to Lightning Cable (Note: USB C, not USB), dé Coiled Lightning Cable 3ft [CarPlay Compatible & MFi Certified], for iPhone 14 Pro Max/13/12/11 Pro/11/X/8/iPad https://a.co/d/03I4m6r
Joe Kelly
St Charles, Mo
1973 Triumph TR-6, 2009 Accord, 2017 Pacifica
I have been told stay with the cord. Generic corded have a problem I purchased a new Apple cord and things improved. You can look on the Apple App page and find what works with Apple play. I was dissatisfied with selection.
PlantMan
Berwyn Heights, Maryland
2017 F-250 4WD crew 8' bed; 2022 Maverick XL AWD
You can search here for discussions on wireless Carplay adapters. iPhone lightning connectors don't hold up well. More expensive wireless Carplay adapters aren't necessarily better. Get yourself a couple of USB-A downwards right angle adapters and you can route the wireless adapter's cable underneath the console and then use some strong Velcro to attach the adapter under the console and out of the way. I suggest you use electrical tape or shrink tubing over the connector joints so that isn't an issue.
This is the wireless CarPlay adapter I use and I'm totally pleased with it. $55 on Amazon.
https://www.amazon.com/gp/product/B09QJXQRPB
I never have to take my iPhone 13 Pro out of my pocket and it connects automatically once you set up the connection the first time.
The Weatherman
Dean
KY
I have had good luck with CarPlay2Air ($90ish) but I have the Sync3 Audio so it may be a different story without it.
Gpp
Gil
Sanford nc
2022 ford maverick
After playing with car play awhile it seems to be alot better than not having it.my daughter gave me a coiled cord she has and it seems to be the way to go.had to give it back though😂thanks from the old man
dadd75
Upstate South Carolina
www.universityofheaven.com
2022 Maverick Hybrid Lariat, 2013 Buick Encore
jsalewicz
Indiana
2023 Ford Maverick XLT Hybrid
My 13 max does the same with USB C, maybe need to go back to standard USB.
