Adding Hard-wired 2022 Keypad to 2024
ptibbs24
Parker
Wisconsin
2022 Maverick Lariat 2.0 AWD
I’ve got a 2022 door laying around that had the keypad in the pillar. I’ve already cut up my 2024 Lariat door pillar and got the keypad mounted to it, but my 2024 door harness did not have a connector for the keypad to plug into (not surprising).
If I swap the 2022 door harness in, will I be able to get the keypad working with FDRS?
Does the wire on the other end of the harness have something to plug in to?
Do you feel comfortable dealing with Forscan settings for at least 1 module to enable wired?
I'm betting at some point when they knew they wouldn't offer it, options to support it were disabled.
The wireless system seems to go thru the fob method, but still some options enabled for code changes.
ptibbs24
Parker
Wisconsin
Yes it does. And yes, I have re-flashed modules before on Forscan so I should be able to figure that side of things out (if it's possible).
BlueSpec1
Gene
