Acceleration Shudder
Tyler29
Reece
Huntsville
2022 Ford Maverick Hybrid
Has anyone had experience with an acceleration shudder that only happens between 20-25 mph? Slow acceleration it’s light but moderate acceleration it’s definitely noticeable and more hesitant to get going. I have an appointment to have it checked out soon but curious if anyone’s had a similar issue.
Waterick
Richard
Laurens county SC
What year is your truck and how many miles?
Waterick
Richard
Laurens county SC
Many posts about shuddering issues. Search: "Shuddering Hybrid" Aug 26, 2022 for starts.
Waterick
Richard
Laurens county SC
Alot of the hybrid clutch shudder issues seem to start earlier. Sounds more like the CV joints/axles. That's also pretty frequent.
Edit: Search: "CV joint or axle failure?" Sep 18, 2023.
Tyler29
Reece
Huntsville
Okay that turned up more results, searching for shudder turns up mostly hybrid clutch which I know it’s not. Goes in next week so I’ll find out then, hoping it won’t take long to fix like people are reporting.
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
If that's me, I'm checking lug nut torque first, 148 ft lbs. Then visually inspect inner/outer CV boots for leaks. I would check for mud in the wheels too and spray them out. Check tires for uneven wear. 36k is high enough for things to come unbalanced. Beyond that, it's a dealer's job.
Check the obvious shit but CVs should be covered under powertrain 5/60?
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Tyler29
Reece
Huntsville
Jonny44
Jon
Minnesota
2025 Mav hybrid AWD XLT, 2016 Ford Escape Titanium
I recently had the same with mine, 22 with 40k. It definitely came from the rear end, though. Lasted for a few seconds and then it was fine. It's getting a tire rotate today, so I'll check it out then.
mikellmikell
Mikell
Southwest Michigan
2 Colorado's
Mines going in Monday for a couple of recalls and I just noticed the shudder yesterday. So I'm adding that. A 22 just turned 30k
Biagio
Biagio
Oakville
2023 Ford maverick
I seemed to be having this same issue 23 xlt eco awd. Everyone seems to be going in the direction of cv joints but mine shudders like it's starving for fuel. From a complete stop to go it's seems I have to push the pedal harder just for it to respond and than it just goes. Even in cruise control doing any speed it just randomly shudders slightly like it's going to stall and you can notice the rpms move a little. Can't see how this is related to cv joints so please tell me I'm wrong cause that might be a lighter issue.
Thanks
son of a ..sven
Oregon
2023 Hybrid
NOT happening on acceleration, but on slowing down. My 2023 hybrid with 5600 miles has shuddered about 6 or 7 times. I brought it to the dealer and the service guide said he knows nothing about a "shudder" and then I explained what it was. Low speed coming to a stop, the front end really shakes up until I stop, around 15 mph. It has Nothing to do with the brakes at all, never touched them. He said there is nothing on the books about that and if I brought it in they would try to recreate the shuddering. I said it happens very rarely. He said they have to experience it to fix it. I am pretty upset, as I see this dealership putting me off and I have no options. Advice?
Ford Motor Company
Dearborn, mi
Thanks
Hello there! Are you still experiencing this shuddering concern? If so, I would like to look into it on my end. Please send over a private message with your VIN and the name/location of your local Ford dealer.
