8 different types of fuses
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
According to the owners manual the truck has 8 different types of fuses.
Ford Maverick 8 different types of fuses 1734903685809-et
Does anyone know of a chart that shows what type of fuse is associated with each fuse slot? For example:
#84 - 20A - Slotted M Case
Thanks,
Ray
BlueSpec1
Gene
Someone posted this Interactive:
https://www.startmycar.com/us/ford/maverick/info/fusebox/2022#anchorfusebox0
Looked thru my fuseboxes.
BJB:
Micro2
2 Low Profile JCASE
Littelfuse 0895040.Z 895 Square Car Fuse 40A Low Profile JCASE Cartridge Fuses Rated 58V
Littelfuse 0895060.Z 895 Square Car Fuse 60A Low Profile JCASE Cartridge Fuses Rated 58V
MCASE+ Slotted:
Ford Maverick 8 different types of fuses Maverick BJB - Littelfuse MCASE+ Fuses
BCM fuses in my 23 XLT
Ford Maverick 8 different types of fuses BCM Fuses 2023 XLT
Ray-n-AVL
Ray
Asheville, NC
Thanks! The under hood interactive one does not match up with what's in the manual. They must have made changes since 2022 but I got it all figured out. I only see 1 JCASE.
Ray-n-AVL
Ray
Asheville, NC
BJB:
Micro2
2 Low Profile JCASE
MCASE+ Slotted:
Did you actually pull the J Case fuses to see if they were low profile? If not, where did you find this info?
Thanks,
Ray
BlueSpec1
Gene
Thanks,
Ray
Pulled them from my 23 2.0L that I had prior to 23 2.5L Hybrid.
Had a 30A to compare to my 60A Low Profile JCASE and MCASE+ 60A HT fm Maverick BJB.
Can read Littelfuse's PNs on some of the fuses and compare to Littelfuse data sheets.
Ford Maverick 8 different types of fuses Littelfuse 895 Low Profile JCASE 40A, 60A
MCASE+, LP JCASE pulled fm BJB, compared to a 30A from another fuse kit.
Ford Maverick 8 different types of fuses 60A HT MCASE+, 30A Low Profile JCASE, 40A Low Profile JCASE
Ford Maverick 8 different types of fuses 23 Maverick 2.0L Ecoboost BJB Fuses-1
Ford Maverick 8 different types of fuses Fuse Kit Micro2, Micro3, LP JCASE, MCASE+, ZCASE, Fuse Puller -1
Ray-n-AVL
Ray
Asheville, NC
Thanks. The reason I wanted to confirm is in the LittelFuse catalog the standard J Case are rated at 32V and the low profile are rated at 58V. Where did you get that fuse assortment kit?
Ray
BlueSpec1
Gene
Ray
Bought 1 for each vehicle. Added MCASE+ Slotted, ZCASE 300A for the Hybrid Maverick & Escape.
3rd vehicle uses LP JCASE, Micro, Mini ATO, MCASE+ Unslotted, so the kits work for me.
Littelfuse 00940570ZXA MICRO2, MICRO3, MCASE Fuse Kit Assortment - 135 Fuses
https://www.ebay.com/itm/115971887254
Ford Maverick 8 different types of fuses 1735835777608-0s
Got the Littelfuse 00970054XPA MCASE Fuse Puller when ordering from Mouser.
Ray-n-AVL
Ray
Asheville, NC
Where is the ZCASE 300A on the truck?
BlueSpec1
Gene
AzureBlueBill
Torrington, Connecticut
That is totally unnecessary over-complication. Ford is obviously determined to make owner servicing nearly impossible!
