kw86er
KW86ER
Vancouver BC
2L XLT FX4
Thanks for the pictures and write-up. I think with the dark truck the rear wheel off-center does not look as pronounced. It is a nice stance with those wild peaks...
I know it's been said a lot that this truck will not be a serious off-road truck but I suspect there is still a lot we can do to improve the off-road capabilities.
With such a low upfront cost of ownership, it will be a popular model for custom work. It will be interesting to see what offerings are available down the road.
CLH917
Travis
Madisonville, LA
As I previously suggested, you might want to visit a new alignment shop. I don’t know of any vehicle in the world that self aligns itself after the install of a lift and larger all-terrain tires. That tire and suspension wear is going to be killer!
The set up looks good though!
Brendan
VT
22 Maverick XL
Looks great, and pretty much what I'm considering (although mine will only be an XL). I know it's only been a day, but have you noticed the difference in acceleration and/or fuel economy? I like the idea of 31s for a bit more clearance in the snowy months, but I'm a bit concerned about the decrease in fuel economy.
MAC_Detail
Michael
So Cal
I think he is more referring to tired scrub then self alignment. When you lift a vehicle(like with a jack) the camber changes with suspensions travel, when you put it back down its still not fully scrubed. This is simply due to the stiction of the tires, and the fact that the suspension cycles on a radius. This will keep the vehicle higher than actual ride height, after driving the vehicle the suspension will scrub and be back to static height causing the camber to come back in. You will definetly need an alignment after doing the lift though.
CLH917
Travis
Madisonville, LA
If you’re referring to my comment…my comment stems from his remarks he made on Facebook in which he said a lady at the alignment shop of his choosing said one was not needed.
Area51Lariatfx4
Gene
Toronto, ON
2022 Ford Maverick Lariat FX4 Area 51
Here it is as promised.
FordRangerLifts 2” lift kit with 235/75-17 Falken Wildpeak AT3W’s. 31” tires.
As noted by other people with lifted truck the rear tire does sit forward in the wheel well. But it’s an optical illusion as to how close. There is at least 3” between the fender and tire towards the front of the rear wheel well. Took some close ups.
Also when you first do a lift kit the tires camber in on the tops, out on the bottom in the front after you set it back on the ground.
Don’t freak out like I did!
As soon as you drive the Maverick after the lift the tires straightens out on its own. 👍
Looking good! Did the lift change anything driving wise?
Mannyr
Manny
Virginia
2019 WRX
Looks great! The tires keep getting bigger and bigger over here 😂 who said 80? Lol.
Question; is the driveway on a slope, or this lift makes the front of the Mav look even more slanted?
Decayed
yes
a car
The main thing is the rear diff. Tires and lifts will only take you so far. No idea if ford is planning on making available the dual clutch rear diff they put in the bronco sport, but it could certainly work since it's basically the same drive train.
MAC_Detail
Michael
So Cal
I was referencing your comment to what the OP stated to hopefully clarify what is going on (to the OP).
Its possible that it was within factory specs, albeit, on the edge. Also possible it was "close enough" and they were just being lazy haha.
Sometimes you also dont have adjustment for caster/camber, but usually still requires a "toe and go".
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
CLH917
Travis
Madisonville, LA
Yeah just based on doing 1" spacers on mine with 30.5" tires and seeing the end results, I'm confident there's no way his truck is aligned to spec lol
Bushpilot
Greg
Spokane, WA
Chevy Volt
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Bushpilot
Greg
Spokane, WA
Chevy Volt
