5 New Maverick recalls this past week ALONE
CurtisB
2023 Maverick XLT Hybrid
Toyota of today:
2021 RAV4 Prime Plug-In Hybrid vehicles due to the risk of the hybrid system shutting down and stalling while driving in EV Mode in cold weather conditions if the accelerator is rapidly pressed.
2022-2023 Tundra and Tundra Hybrid vehicles that have a Toyota genuine accessory tonneau cover. NHTSA said the cover may detach if the tonneau cover attachment joints become loose.
2022-2023 Corolla Cross vehicles due to a manufacturing defect in the instrument panel. Improper deployment of the front-passenger airbag violates safety regulations.
2023 Camry and Camry Hybrid. The lug nuts that connect the wheels to the vehicle may not have been tightened properly, which can result in the wheels detaching.
2023 models, including Corolla, Corolla Cross, Corolla Cross Hybrid, Highlander, Highlander Hybrid, and Tacoma, as well as 2023 Lexus RX350, RX350 Hybrid, RX500 Hybrid, and 2023-2024 Lexus NX250, NX350, and NX350 Hybrid vehicles due to an issue with the electrical connection inside the steering column's spiral cable assembly. NHTSA said this may have caused the driver's airbag to deactivate.
2021-2022 RAV4 Prime and 2022 Lexus NX450h+ plug-in hybrid electric vehicles on July 12 due to a potential electrical short-circuit caused by a damaged electric current rectifying module in the DC-DC converter.
2022-2023 Tundra and Tundra Hybrid vehicles due to a potential fuel leak caused by a plastic fuel tube rubbing against metallic brake lines.
2013-2018 RAV4 vehicles. The NHSTA said replacement 12-volt batteries may not fit properly in the battery tray, causing the battery to move and contact the hold-down bracket, which could result in a short circuit.
2023 Toyota GR Supra models due to a manufacturing defect with the weld seam of the integrated transmission control unit's cover. This issue could've caused automatic transmission oil to leak into the transmission control unit, leading to hazardous driving conditions and potential damage to the vehicle.
I can keep going if you still want to compare your 'older' Toyotas to current Fords. I can make a list just as long for Honda as well.
Totally agree with your post. We now drive computers, not just vehicles, so, they are going to have more issues than my 1972 Datsun 510. Todays cars have sensors, connectors, wiring harnesses and computers that are subjected to human error as well as the worst elements (weather).
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Its worse than that - the engineering quality and the line checks have both gone down the toilet. Having a Toyota transmission that partially engages while in neutral or inadequate axle mounting bolts that shear off on the highway is like running with scissors and then wondering why they're in your chest when you fall. Don't even think about the full engine replacements on all Tundras to partially fix their multiple design issues. Or Nissan putting a ridiculously undersized CVT in their vehicles and then expressing surprise when they fail is just plain poor engineering. Toyota and the other Japanese competitors are no better than Ford in this regard, and may actually be worse. If you think GM is better, take a look at their engineering debacles of late, like all 2.7L owners getting a long-block due to pinholes in the slimmed-down castings. I drive a Ford and thank god that I don't own a GM or a Toyota.
First Sergeant
Fruitland Idaho
Toyota of today:
No need for the list. My comparison was "older Toyota vehicles not the newer. The newest Toyota I have owned was 2014 4Runner and like I said no issues out of it or any of the older ones. You do make a couple good points and I do appreciate someone who does their research! I noticed a difference in recalls of the mentioned on newer Toyota's and newer Fords. Toyota recalls seem (except for the 2021 Rv4 Prime you mentioned) to be mechanical in nature, while most of Ford recalls seem to be software (especially our Mavericks) related. Not sure why that would be. That said, I really enjoy our Maverick Hybrid (wish I would have known the 25 would be available AWD Hybrid) and will keep it for a long time, as we do most vehicles. Reliability and dependability shows up well after many years and miles. The Toyota's I have passed to my kids have gone close to 300,000 and some have been sold off to buy newer ones. I hope they get the ones without issues! Thanks for your writeup, great info!
MikeS1942
Windsor Ontario
24 Maverick Lariat
Well I sold my Honda in Feb 2024, after I received my Maverick in Jan 2024. But yes, it was a 2009. Sold my Toyotas recently too, and yes they were both 2007 models. So admittedly don't have experience with models produced in the last 15 years. Guess I'll just keep my mouth shut about the 15 and 16 years of no recall ownership.
So why would you buy a Maverick if all these years you've had all this wonderous luck?
First Sergeant
Fruitland Idaho
May have been like me and needed a vehicle to tow behind motorhome. Getting harder and harder each year to find a flat towable from any manufacturer. I have had many Toyota vehicles all dependable and with very few issues. These were all previous to 2015 (older models) but none of them (then and now) can be pulled behind a rig. Kind of strange, because Ford had bought the technology I think for the ecvt from Toyota. Maybe it is not the same "transmission". Edit: I had a 4 speed 1980 Toyota pickup (manual transfer case) that you could tow behind you and I'll bet about anything with manual transmission is towable.
Jimmyland
Pennsauken, NJ
2023 Ford Maverick
I am waiting a while to see if there are more recalls so they can be done all at one trip to the dealer 20 miles away. My truck has never let me down in 30k miles so far.
Usually the software updates can be done in your driveway by Ford Mobile Service. Had the only 2 software recalls done at my home by them. Very convenient.
MikeS1942
Windsor Ontario
24 Maverick Lariat
It would be great to have the option of a manual transmission. Stick it in neutral and go. Just as long as you don't loose the rear seal on the tranny while your towing. My brother-in-laws Miata suffered that fate.
First Sergeant
Fruitland Idaho
Yeah, I would like a stick again. Also, easy to work on and inexpensive to repair compared to the automatics. Problem is, these kids could not master it I don't think. Imagine texting, and having to shift at same time! Hahaha. And working both feet while doing the above. Put headlight dimmer and starter button back on the floor and they would be toast!
First Sergeant
Fruitland Idaho
Yeah, I would like a stick again. Also, easy to work on and inexpensive to repair compared to the automatics. Problem is, these kids could not master it I don't think. Imagine texting, and having to shift at same time! Hahaha. And working both feet while doing the above. Put headlight dimmer and starter button back on the floor and they would be toast! What ever happened to manual lock out hubs on our 4X4's? Those were easy to fix and cheap also.
MikeS1942
Windsor Ontario
24 Maverick Lariat
It would help to cut down on car theft.
FischAutoTechGarten
Peter
Simple, because the Maverick replaced both 18 and 15 year old vehicles. We are a 1 vehicle family, with the '2nd vehicle' being an electric golf cart .. Maverick fits in the carport where the CRV resided.
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
Once again, these are not new recalls. Please do your research!
One of those recalls shows a total of two units were affected, which means one dealer screwed up I’m loving my 45 mile per gallon lariat Maverick and I had one recall for the tail light 2023 certainly the best vehicle I’ve ever bought for under 40k
