265/60/18 tires on stock Lariat?
Demosouthpaw
Jay
T A M P A
23 Maverick - 21 Bronco - 53 Merc
Hey forum,
Done a good amount of lurking recently but cant seem to get a definitive answer on this topic.
Personally I like the look of my 18's, I want to give the truck an aggresive look. I was thinking going with these tires
BFGoodrich All Terrain T/A KO2 Radial Car Tire for Light Trucks, SUVs, and Crossovers, LT265/60R18/E 119/116S 119S https://a.co/d/bXLZdDC
Throwing around the information gained here plus some addition it would appear these tires would fit stock with slight to no rubbing (see below)
Ford Maverick 265/60/18 tires on stock Lariat? Screenshot_20230430_191736_Chrome
Ford Maverick 265/60/18 tires on stock Lariat? Screenshot_20230430_191929_Chrome
I would like for someone to go over this (if possible) and double check me on it. Let me know your thoughts!
Thanks!
Discount Tire
Diamond Sponsor
Arizona, USA
discountti.re
All Things FORD
I have seen the 265/70R17 on the Maverick. That tire stands 31.5 inches tall depending on brand. The 265/60R18 stands roughly30.50" tall. In theory, you should be ok.
Demosouthpaw
Demosouthpaw
Jay
T A M P A
Thanks for the speedy response, I'm going to hold you to "in theory, you should be ok" jkjkjk looking forward to slapping those Ko2's on her.
Demosouthpaw
Demosouthpaw
Jay
T A M P A
One last question diameter being addressed at 30.5" would width be called into question given that it is 10.4".
Thoughts??
Discount Tire
Diamond Sponsor
Arizona, USA
discountti.re
All Things FORD
265 mm translated to inches is 10.43 inches. Mounted on a 7" wide wheel you will be closer to 11" overall width from sidewall to sidewall. You should be OK.
JP4AZ
Phoenix
Hey forum,
Thanks!
I can't wait to see the results. I have the same plan for my XL Awd. Please keep us posted. You are going to have stock suspension right? My hopes are to keep it stock, I have a 1" level kit already (if I feel I need it).
Thanks!
Demosouthpaw
Demosouthpaw
Jay
T A M P A
Thanks!
Yeah planning on leaving the suspension stock and stuffing those wheels under there.
Took a pause on that project as I'm install a few mods first before the wheels go on.
JP4AZ
Phoenix
Are you still on Pause? I found some 265/60/18 Hankook AT tires I had mounted and balanced.
My Maverick should be here any day now. Just wanted to see if you had any progress on your project?
Ford Maverick 265/60/18 tires on stock Lariat? 20230525_111638_resized[3567]
Demosouthpaw
Demosouthpaw
Jay
T A M P A
Trying to find time in between work to get this going. I did manage to get my CAI and BOV installed. I dont trust shops so im limited to when I get a break.
Ford Maverick 265/60/18 tires on stock Lariat? 20230513_132131
Ford Maverick 265/60/18 tires on stock Lariat? 20230513_132122
Ford Maverick 265/60/18 tires on stock Lariat? 20230513_132118
JP4AZ
Phoenix
Sweet! Let us know if you can feel the power with that cold air intake.
Demosouthpaw
Demosouthpaw
Jay
T A M P A
I want to say yes, I can feel the power. But I know its subjective. The noises are cool though, sounds like a jet when spooling up.
AugMec
Augustyn
Florida, USA
2022 Ford Maverick Lariat
Just curious if you compared the BFGoodrich All Terrain T/A KO2 to the Toyo Open Country AT3's? I have been looking at both online and also plan to add them to my otherwise factory Lariat Hybrid to make it look a bit more truck-like. If you (or anyone else on this post) have looked at the two and know which are better i would appreciate the info.
The Toyo's can match and/or come very close to the stock tire size so i feel it would be a better option. https://www.toyotires.com/product/open-country-at3/
JP4AZ
Phoenix
Demosouthpaw,
just an update, the 265/60/18 fit perfectly on stock suspension, no rubbing! The wheels are 18x8 with a 40et. Super happy with the fit and ride. Plenty of power. The truck only has 53 miles on it so I can't tell you about mpg. I don't care, it looks great and fills up the wheel wells with minimal poke out. Best of luck with yours!
Ford Maverick 265/60/18 tires on stock Lariat? 20230602_111811_resized
Ford Maverick 265/60/18 tires on stock Lariat? 20230602_111825_resized
Demosouthpaw
Demosouthpaw
Jay
T A M P A
Demosouthpaw,
Hell yeah!!! Im digging those rims too!
wb5oxq
Waco Texas
2023 Maverick Lariat in Alto Blue
Hey forum,
Thanks!
That should work but may reduce your fuel economy.
