2025 Lariat Hybrid CVT Temp
jasonojordan
Jason
Grand Rapids MN
Ordered 2025 Maverick AWD Hybrid Lariat
Has anyone found a way to display "Transmission" temp while towing? Either on the truck itself or using Torque Pro?
jasonojordan
Jason
Grand Rapids MN
Regardless what you want to call it has anyone found a way to monitor its temp.
710-oil-614
Cal
2025 Hybrid AWD Lariat
It is not really "what you want to call it"....that is what it is and it differs significantly from a traditional CVT.
jasonojordan
Jason
Grand Rapids MN
That may be so but for the sake of the question asked in the thread it really doesn't mater what you call it.
But thank you for clarifying.
bgn
WA
Forscan offers monitoring of the transmission fluid temp on the EcoBoost. It's probably available on the hybrid as well. I assume most other apps will offer that functionality.
jasonojordan
Jason
Grand Rapids MN
Thanks, I'm hoping for something that can be monitored from my phone.
jasonojordan
Jason
Grand Rapids MN
Forscan on Android supports these. The iOS version probably does as well.
Gotcha, did not realize forscan was mobile as well as pc based.
jasonojordan
Jason
Grand Rapids MN
Looks like forscan has not been updated since end of last year and is no longer on the marketplace.
Downloaded a older apk trial and tried it and it won't connect to the truck. Googling it sounds like it's a known issue and that in my research I did not find anyone who was able to get connected.
710-oil-614
Cal
Interesting. Plenty of 2025 owners have been able to download the latest version and connect to their trucks.
It was removed from the Marketplace way back, as Google requirements changed.
You can read all about it on the forscan.org website - where you can also download the apk that had an update maybe a month ago and still works fine.
Use their list of OBD recommended devices.
Now when you search the PIDs, you know to search for correct ecvt.
Though actually, temp would be better search.
jasonojordan
Jason
Grand Rapids MN
Then I must be a big idiot.
