2024 hybrid check engine light on
Memosmaverick
William
Imperial Beach
2024 Maverick
My check engine just came on my 2024 hybrid. So I had it checked was told it's my exhaust manifold. What gives? I called my local Ford dealership for an appointment and my earliest is November 26th. So my next dealership is 120 miles away. I called them and they have one for the next day. Made my appointment. Any other has had this problem?
Mavster Mechanic
Hybrid
Did you get a code?
Do you know how to get the code?
The DTC - Diagnostic Trouble Code.
MO HORSE
Springfield MO USA
2024 Maverick XLT
I have a 2024 Hybrid XLT and the same thing happened to me a week after I bought it.
Dealership fixed it in a few days. Exact same issue and no problems since.
Mavster Mechanic
Hybrid
P237f
Exaust Heat Exchange Bypass
"This DTC sets when the PCM senses a valid position but has not changed since start up."
Possible Sources
Wiring, terminals or connectors
BJB Fuse 8 (15A).
PCM
Frozen valve / Broken linkages Valve alignment
Faulty position sensor
Clogged heat exchanger
Hoses
Coolant leaks
Visually inspect the exhaust heat exchanger for damage or signs of failure. Residual condensation from normal operation can freeze the exhaust heat exchanger valve restricting its movement. Using the Hybrid Engine Running Diagnostic Mode, run the engine to operating temperature to melt any residual ice build-up in the exhaust heat exchanger.
Did you get a sudden cold snap?
Memosmaverick
Memosmaverick
William
Imperial Beach
2024 Maverick
Possible Sources
BJB Fuse 8 (15A).
PCM
Hoses
Coolant leaks
No sudden cold snap, I live in the desert, and it's been in the mid-90s. Today I dropped it off at the dealership, and was called later today that it was ready, and that there was an alert that there was a problem with the exhaust valve, and an adjustment was done.
tap, tap, tap
"I heard it move - done!"
