110v need outlet not working
randymeeker
Randy
Kansas City
2024 Ford Maverick 2020 Transit Connect
2024 Lariet Hybred - tried to use the 110v outlet in bed and no power. Thinking kitty might be a fuse, pulled fuse box. According to manual and internet, I should have a number 84 fuse. Per the photos not only do i not have a #84 fuse but there no contacts in box (like fused before and after) for a fuse to work. Am I wrong or do I have an incorrect fuse box?
Update - not 85 but 84 and both it and #6 in interior fuse box are good. Dremel rotary tool used for testing. Neither interior note needed outlets are working and no indicator light in bed outlet.
9/28/26 update - Had an appointment for tomorrow morning and decided to check the connection just inside the frame inside the right rear wheelwell. Connection was intact but just for giggles, disconnected and reconnected the plugs and now both outlets work fine. I appreciate all the suggestions and corrections.
Ford Maverick 110v need outlet not working 20260925_155951
Ford Maverick 110v need outlet not working 20260925_155940(0)
Ford Maverick 110v need outlet not working 20260925_155910
Ford Maverick 110v need outlet not working 20260925_155904
Ford Maverick 110v need outlet not working 20260925_155855
I have a 23 hybrid both of my 110 outlets work.
I really wanted to help you out by taking a look at that fuse panel, but it's a little more than what I want to go through pulling it out. Sorry
BlueOval1954
Doesn't the vehicle have to be running in ordered for the 110V outlet to work ? It does on the Ecoboost but not sure how it works on the hybrid.
randymeeker
Randy
Kansas City
This is the #84 fuse. The slots below are empty, yet numbered.
HRG
Ok, thanks. That makes sense. I couldn't say for certainty but assumed i had tested that outlet when I first bought the truck.
Ranko Kohime
Ranko
2025 Maverick XLT
If you get to the point where you have the indicator light on either (hopefully both) outlets, your best bet is to try a resistive load such as an incandescent light bulb. LED should also be resistive, but it’s a bit of a crapshoot there. The modified sine wave nature of the inverter, coupled with it’s low wattage severely limit it’s utility.
I used Night Lights to demonstrate the 110 outlets in another thread.
Of course you can see the little amber light illuminated.
Ford Maverick 110v need outlet not working IMG_20260918_163012
