10k Checkup
WiscMav
Chuck
Wisconsin
2024 Maverick
Did you folks do the 10K checkup? Does skipping it cause warranty problems?
Thanks!
Berg56
Mitchel
Tucson, AZ
Subaru Forester
My 2024 XLT hybrid is a year old, 4,900 miles. I just had the fist service done, I get free lifetime oil changes, tire rotation and inspection. I would think if you don’t have service done at required intervals whether it’s miles or time, mine will be 2 years old before it hit’s 10K, it would void the warranty.
Cherokee
Marty
2026 Ford Maverick Tremor
Never heard of a free 10,000 mile check up.
I only go in for regular maintenance, oil changes and such.
Berg56
Mitchel
Tucson, AZ
Subaru Forester
OK well it wasn’t the 10K checkup sorry, just the regular maintenance. isn’t 10K the standard first oil change interval? Also they came and picked up the truck and bought it back and did the rear camera recall. We only have the one vehicle so that is a great service, they also will come to your location and do the service but we don’t have a garage or paved driveway, plus it was 113 degrees yesterday.
Cherokee
Marty
Don’t know about the Mavbrids but my Ecoboost got its first oil change at 3,000 miles. Because I wanted a load of
Full Synthetic In my engine.
Berg56
Mitchel
Tucson, AZ
Subaru Forester
We hardly drive it, a bit over and year and less than 5K. I think considering that and that it’s a hybrid the synth blend is OK.
Oil change interval is whatever the OLM reports if going by that. May hit 10K, may hit 1 yr first.
The 10K check is a bunch of items listed in the manual, many that allow discovering issues before they become big. Rotating tires is every 10K also. Filters are brought in at 20 & 30K, ect.
@WiscMav
Warranty would be involved because of finding issues.
And your manual actually lists several items for 6 month check - but mainly safety things.
Owner Checks and Services
Make sure you perform the following basic maintenance checks and inspections every month or at six-month intervals.
Check Every Month
Engine oil level.
Function of all interior and exterior lights.
Tires, including spare, for wear and proper pressure.
Windshield washer fluid level.
Check Every Six Months
Battery connections. Clean if necessary.
Body and door drain holes for obstructions. Clean if necessary.
Cooling system fluid level and coolant strength.
Door weatherstrips for wear. Lubricate if necessary.
Hinges, latches and outside locks for proper operation. Lubricate if necessary.
Parking brake for proper operation.
Seatbelts and seat latches for wear and function.
Safety warning lamps (brake, ABS, airbag and seatbelt) for operation.
Washer spray and wiper operation. Clean or replace blades as necessary.
Multi-Point Inspection
In order to keep your vehicle running right, it is important to have the systems on your vehicle checked regularly. This can help identify potential issues and prevent major problems. We recommend having the following multi-point inspection performed at every scheduled maintenance interval to help make sure your vehicle keeps running great.
Accessory drive belt(s) Hazard warning system operation
Battery performance Horn operation
Engine air filter Radiator, cooler, heater and air conditioning hoses
Exhaust system Suspension components for leaks or damage
Exterior lamps operation Steering and linkage
Fluid levels1; fill if necessary Tires, including spare, for wear and proper pressure2
For oil and fluid leaks Windshield for cracks, chips or pits
Half-shaft dust boots Washer spray and wiper operation
1 Brake, coolant recovery reservoir, automatic transmission and window washer.
