1/4 Mile 93 vs 87 Lobo
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
I use Costco also. I wait until tank is low, add 9-10 gallons of 87 and the last 2-3 gallons of higher octane. 95% of the time I get 42.0 to 44.5 mpg on with the mixed octanes, only 37-38 mpg on the 87 octane...but my Hybrid is noticeably quicker with my blend of the two octanes.
The Real Maverick
Jack
2025 Lobo, costco gas
Dragy verified, same road, same temp, weeks apart
87 - 14.62 @ 92.21 0-60 6.25
93 - 14.71 @ 93.02 0-60 6.47
Mpg is pretty much the same as well, premium vs regular.
Thanks for posting.
I'm not saying you did; but even IF you make a mistake typing and inverted those numbers, it's close enough for me to call it a tie. No difference.
The Real Maverick
Jack
ran it again with 90 ethanol free. same place, same temp, same launch rpm. slower
14.72 @ 91.70
0-60 6.39s
0-60ft 2.15
In "some" markets the higher octanes have higher ethanol content, which eliminates knocking, but lowers energy content at the same time. 🤷🏻‍♂️
V8Demon
Farmingdale NY
2024 Ford Maverick Lariat, 2005 Supercharged Ford Mustang GT
90 eFree - 14.72 @ 91.70 0-60 6.39
14.72 @ 91.70
0-60 6.39s
0-60ft 2.15s
Weeks apart...
The same temp doesn't necessarily mean the same density altitude. I'd be MUCH more curious to see what that was for all the runs.
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
14.72 @ 91.70
0-60 6.39s
0-60ft 2.15s
As a comparison, I had a '66 Corvette 327/350 hp, 3005 pounds, 3:55 posi / 4-speed that did the 1/4 in 14.14 sec / 101 mph with street rubber. Went through the traps not quite at red line in third gear.
Those times in a 7800 pound Maverick are impressive. No doubt due to better AWD traction off the line, 7 gears instead of 4 and the near instant torque of the EB 2.0.
Ford Maverick 1/4 Mile 93 vs 87 Lobo 66 Corvett
Tbone289
I'm assuming you meant to type 3800...
Buggy Man
Summerfield Fl
According to the NY registration the '66 Corvette roadster that I had weighed 3005 pounds
wax87
Stuart
Dallas South
2004 Avalon
14.72 @ 91.70
0-60 6.39s
0-60ft 2.15s
Why is it faster on 87 octane?
MosesP
San Antonio
Lobo
Looking at it now, it had a lower slope %. Trying again with 93 and hopefully the same slope.
Weeks apart...
[/QUOTE
Same same. Updated original post
wax87
Stuart
Dallas South
2004 Avalon
"Lower slope%" Not sure what that means. Did you get a better jump on the 87 run?
Tbone289
I'm not questioning that. The Maverick doesn't weigh even half of the 7800 pounds you stated. 3800 pounds is accurate for a AWD EB Maverick, thus my prior comment.
MosesP
San Antonio
Lobo
Weeks apart...
down grade of the road I was on
Buggy Man
Summerfield Fl
YOU ARE 100% correct. I don't know where the 7800 # came from - must be a senior moment.
That would have been quite an achievement to pull 7800# with only 250 hp in 14+ seconds in the 1/4.
Thanks for the correction.
