Tom H
Thomas
Round Lake Park, Illinois
2025 Ford Maverick 2WD Hybrid
I couldn't find A Ladder Rack that didn't require drilling holes.
So, I built my own using Unistrut and Unistrut brackets, you might not see it in the picture, but I used a 10-inch piece of 1 7/8 Unistrut with the 3/8 clips it works great.
Ford Maverick Ladder Rack DIY setup installed on my 2025 Maverick 241628-ce01c18e5af1d5aa9cf533c1218debea
Ford Maverick Ladder Rack DIY setup installed on my 2025 Maverick IMG_0426
Ford Maverick Ladder Rack DIY setup installed on my 2025 Maverick IMG_0427
Ford Maverick Ladder Rack DIY setup installed on my 2025 Maverick IMG_0429
Ford Maverick Ladder Rack DIY setup installed on my 2025 Maverick IMG_0428
Cancunbadlands
Cancun
Cancun
So you can't close the bed cover now
Prickly Pear
Pacific Northwest
24 Maverick XLT CG, 92 Ranger
That's pretty cool - I like that you can disassemble for storage. I looked at your design and thought about welding something like that up, but then you are stuck with bulky "monuments" that you have to figure out what to do with when they aren't on the truck!
Tom H
Thomas
This takes up just a small amount of room in the shed, the only ones I found at the time you had to drill holes in the bed, which would rust later this uses the existing rail system that comes with the truck and come winter time I can use the cover, one more point I used an inner tube for a bike and used rubber cement to put on the bottom of the brackets that touch the bed of the truck
urwatuis
Melyssa
Vermont
2023 Maverick XL
urwatuis
Melyssa
Vermont
2023 Maverick XL
looks great. easy to take in and out. very strong. versatile, just like the Maverick
markinvictoria
2023 Maverick XLT
I also have a soft roll up bed cover on it now...just roll it up to the back window when using the headache rack. Rack and bed extender is on or off in a couple minutes. Not real pretty but I only use the rack a few times a year.
tpollauf
Toledo/Port Clinton, Ohio
1992 F-150, 2009 Pontiac Vibe GT, 2026 Maverick Lariat Hybrid
Nice work! :) I take it you used the painted steel (green) Unistrut vs the galvanized plated type. I plan on doing something similar and will consider the possibility of something under the front bumper to support an additional front support/rail. This way I could haul a 20-24' extension ladder. We'll see once I get my Maverick!
