Wolfbox's Powered Retractable Tonneau Cover Installation
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
Yesterday, I popped the shipping bands and opened the box with my recent prize award, Wolfbox’s Powered Retractable Tonneau Cover. The box is heavy requiring a two-man lift or a HD moving dolly. Each item appears to be well packed with adequate cushioning material separating the contents. I spent the next hour reviewing the accompanying installation booklet. First impression - the instructions are straight forward and well laid out. Each step incorporates a multitude of detailed drawings.
My first surprise from reviewing the instructions was a realization that installing the cover will necessitate removing and losing the utility of several accessories and modifications that have been a part of my build. This is due to the tonneau being anchored by brackets to the truck bed’s side cargo rails. While I may be able to use several of my DIY rail- adjustable anchor points, I will lose the function of Mabett’ sliding bed divider/Molle panel. With the divider, I also lose a pair of attached Maxzina’s ratcheting tie down straps. I had modified a second pair of tie downs to slide and anchor along the length of the rails. This capability will also be lost. I may be able to mount this pair on the rail in between the cover‘s brackets without the ability for them to move. With my calibrated eyeballs, It appears I will be able to retain the mounted Maxzina front Molle panel. My major loss at this point, is the inability to install a Tyger sports bar that has been awaiting installation in my garage. My hope is that following the installation of the cover, I will identify a means to incorporate the two.
As I begin the installation process, I’ll be returning to post photos and comments of my experience and how I might recover some of the utility lost with stripping out prior mods. Thanks to Wolfbox for their cover and their continued patience while I go about its installation.
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_2152
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_0015
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_0017
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_0021
BK007
BK007
OH
My first surprise from reviewing the instructions was a realization that installing the cover will necessitate removing and losing the utility of several accessories and modifications that have been a part of my build. This is due to the tonneau being anchored by brackets to the truck bed’s side cargo rails. While I may be able to use several of my DIY rail- adjustable anchor points, I will lose the function of Mabett’ sliding bed divider/Molle panel. With the divider, I also lose a pair of attached Maxzina’s ratcheting tie down straps. I had modified a second pair of tie downs to slide and anchor along the length of the rails. This capability will also be lost. I may be able to mount this pair on the rail in between the cover‘s brackets without the ability for them to move. With my calibrated eyeballs, It appears I will be able to retain the mounted Maxzina front Molle panel. My major loss at this point, is the inability to install a Tigre sports bar that has been awaiting installation in my garage. My hope is that following the installation of the cover, I will identify a means to incorporate the two.
Wow you had to remove all of your build to install it!? Hard Pass!! If I won it I would sell it lol 2k+$$!!! My roll up cover is just fine. 🤷‍♂️
AbnRgr
AbnRgr
Athens, AL
I have to admit that now that the main unit is out of the box and sitting on one of my work benches the thought has crossed my mind. In addition to the weight, the unit is large. Tin my case there is sacrifice of cargo space for the benefit of more secure storage in the bed and the luxury of the remote controlled retractable cover. Nothing is lost, everything removed can go back in place if I choose.
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_0022
Ford Maverick Wolfbox's Powered Retractable Tonneau Cover Installation IMG_0023
BK007
BK007
OH
