Windshield washer issue?
Ford Motor Company
Official Ford Account
Dearborn, mi
Wondering if anybody else has had this issue with their windshield washers🤔 I noticed my driver side washer barely squirted water and the passenger side had no spray. I did not get a windshield washer fluid level low notification but I filled it up anyway thinking there must be something wrong with the warning light. After filling up the reservoir I still had the same small spurt of fluid on the driver side and nothing on the passenger side☹ Not sure what to try next but I have a 450 mile trip to make this week and service appts. at Ford are several weeks away☹
GreenLady
GreenLady
Jeannette
NE FL, NC, SC
There is a connection where the hose T's. Pull the tubing off at each connection and also at the nozzles trying the washer until you can isolate which section is clogged and then replace that section. Tubing and nozzles are cheap and available at most parts stores.
Thank you! I will try that today.
Mwc1184
Charlotte nc
Nissan frontier
Might try a small needle in sprayer openings to see if clogged.
Penasco
2019 Outback, 2005 Tundra DC
In my Hybrid Lariat the windshield washers are way too powerful. They spray the contents on the roof and on the front doors.
Sembazuru
Wilmington, de
2023 Maverick XLT Lux Hybrid
That might be mis-aligned sprayers. In cars of old you could tweak where the washer jet went by (carefully) putting a needle into the jet opening and moving the far end of the needle around. I'm not sure if that works on modern cars though.
GreenLady
GreenLady
Jeannette
NE FL, NC, SC
After trying several of the solutions suggested I finally had my dealer appointment which included my wiper fluid issue as well as one of the 2 or 3 recalls. It turns out they called it “wiper jets failure” and have ordered the parts. Hopefully no shortage on those and I will have new ones before my next trip north 🤞🏻
GreenLady
GreenLady
Jeannette
NE FL, NC, SC
Interesting to see my post from Oct/Nov about my windshield washers. The solution was replacing the jets which worked until last month when I no longer could hear the washer motor.
Of course it was another month before I could get an appointment so I added it to my airbag recall. As we all know the dealer won’t order parts based on my diagnosis so when I got a call from the service manager yesterday apologizing for the damage done to my truck when it went up on the lift he told me they had ordered a new washer motor, like I should be happy? Once they get it back from the collision repair shop they will install the motor. Sure hope to get my truck back since I’m leaving on Sunday.
Am I the only one with a windshield wiper issue?
DoubleNaught
Maverick has proprietary nozzles and cost about $20 each
bykerhd
Kenneth
Sunny Florida
2023 Maverick XLT 2.0L Ecoboost FW
Whatever you do, make sure that blue windshield washer reservoir cap is snapped down tight.
Mine went missing after a Ford service ? Whether the tech failed to snap it down, or what ?
No way to be sure.
That little piece of blue plastic cost over $ 38 dollars, $ 41+ after tax at the Ford dealer.
Probably 50 cents for Ford to make the darn thing.
