windshield washer reservoir
acaron47
Allen
Daytona Beach, FL 32124
2022 Ford Maverick Lariat Hybrid
Filled the reservoir with some OLD washer fluid and a glob of semisolid washer fluid went into the reservoir. Now the windshield washer system will spray a spirt and then nothing. So wow do I unclog my windshield washer reservoir?
MM Mav
Amy
Great Lakes Region
Frenchy6784
Jean-Louis
Galt, CA
2025 Maverick lariat
You could try disconetting the hose off the bottom of the pump and blow air, from an air compessor with low pressure, backwards for the jets hose connetters. a garden hose maybe into the fill hole to flush the tank. All else fails try removing the tank and remove the pump. Good luck.
acaron47
Allen
Tried using the shop vac with hose put into filler neck and no luck so I have "Mav" scheduled in the shop early Saturday morning.
