Winch in front bumper?
Maverickman74
Shane
Maui HI
Why not just use a receiver mount winch plate and a pair of jumper cable clamps, to make a portable unit to keep in the bed that you can either use hooked to the front hooks with a strap or just inserted in your hitch on the rear. All you need is to bolt one of those 10,000lb D-rings to the winch plate for when you use a strap.
smoncrief
Marietta, OH
94 and 96 Ford Ranger, 23 Maverick/XLT/EB/AWD/SIBL
There is a draw bar kit for towing the XLT/Lariat behind an RV. That's a lot of weight to pull, so if you could weld on to the draw bars you could technically put a winch plate on
https://www.etrailer.com/Base-Plates/Ford/Maverick/2022/BLU88XR.html?VehicleID=20226007465
I was looking at doing this to my XLT Mav when I get it. I like the Roadmater setup better because you don't hav to cut holes into the exterior of the bumber. Maybe use to mount a grill guard and or winch. etrailer | Roadmaster Direct-Connect Base Plate Kit Installation - 2022 Ford Maverick - YouTube
Winds of Change
Chicagoland
2023 Bronco sport,
Solodriver
Glen
Edmonton, Alberta
2024 Tremor XLT Azure Grey
For myself at least, until there is a thoughtfully engineered front winch mount location, I may just go with a hitch mounted one, and keep it light duty.
