Will these fit on my 25 Lariat with 19" wheels?
Johnkn
MD
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Different bolt pattern....they would've looked sharp on your ride though....
Cancunbadlands
Cancun
Cancun
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
Thank you, so would the factory tires 225/55R19 be compatible with those rims or would I have to get new tires.
That tire size should fit with no issues. Although 235's would be optimal but no issues with 225's.
Johnkn
MD
Yes, see picture.
Why would you provide incorrect information to the OP when the question has already been correctly answered (with proof)? Your Google picture further confirms those wheels will not work on a Maverick.
NO, THOSE WHEELS WILL NOT BOLT ONTO A MAVERICK. SEE MY POST #3
RyuRonin1977
Tristen
Virginia
2025 Ford Maverick
Because they fit our 2025 Maverick.
Johnkn
MD
Ummm, no they don't unless you've changed all the hubs and bolt pattern on the Maverick.
Did you change all the hubs and bolt pattern on your 2025 Maverick truck?
The 2025 Ford Maverick features a 5x108mm (also known as 5x4.25-inch) wheel bolt pattern across all trims, with a 63.4mm hub bore.
The DE9Z1007B wheel, commonly used as a 19x8-inch OEM alloy rim for 2013-2019 Lincoln MKT models, features a 5x114.3mm (also known as 5x4.5 inch) bolt pattern.
dfwjjr
Jody
Fort Worth, TX
2025 Maverick Lariat
For what it's worth-the seller said they would not fit.
Allen King Jr
Allen
Springfield Missouri
2019 Grand Caravan GT, 2006 Mercury Mariner
When in doubt, check tirerack.com and do it on 2 open tabs showing each vehicle with side-by-side comparison
