Whats the price on Continental stock tires
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Tread wear, traction and temperature are printed on every tire sold in America. Most of these “tests” are no doubt under ideal conditions but they are a baseline. If your tires don’t include these you shouldn’t buy them. Even the cheapest Chinese tires have these ratings. Tread wear will be represented by a UTOQ 500 (500 generally meaning 50,000 mile warranty) a 100 or less will be for a high performance (sticky) tire. UTOQ 600-700 would usually be for highway tires. Temperature ratings are simple A,B,C A represents the best temperature resistance (tires generate heat as they roll down the road). Traction ratings are generally by the type of tire, ie; AT, AS, highway, mud terrain etc. And just as an fyi the 3 peak mountain snowflake symbol is kind of a joke. The “testing” to achieve this rating is ridiculously simple. It must prove better traction than a typical mud/snow rated tire🙄. Lots of gray area there. A “severe snow rated tire may not have a UTOQ tread wear rating due to the very soft rubber compound. While I don’t work in the tire industry I consider myself a fairly well educated tire geek 🤷🏻‍♂️.
Yes, all very good, and if you drive like my GF (WOT) you need good traction, etc. 🤪 But still, no rubber longevity rating for hostile climates. If you lived in Tucson and drove like my avatar when the sun is shining, all those other ratings put together wouldn't really matter as much as climate durability.
Razor802
Hayden
Manitoba
24 XLT Hybrid
My stock continental tires are down to 5/32 with 21000 km (13000 miles). One has been replaced at my expense with a t-shaped tear from a rock. @Ford Motor Company should be ashamed of their lack of tire warranty and terrible tires on my new maverick.
Vaportrail
Arizona
XL
I found a used wheel and tire set off a bronco sport locally listed for $200-
They're 17's and have the same conti tires that came on my Maverick...
Guy took $180!!!
splitxc
Brett
$162 per tire at Tirerack. 4 of 5 star rating. That is good.
Uniroyal Laredo AT on sale $112 per tire if you are seeking a bargain.
Just got these for my 2023 Hybrid
