There was a short sequence I did to program it to the truck detailed in the Manual.Was this just plug and play or did they have to program it?
https://www.mavericktruckclub.com/f...-2020-escape-maverick-and-bronco-sport.15678/
"VSS Module - Optional Vehicle Security Features
26. Start with ignition key OFF, doors unlocked and VSS system DISARMED.
27. Place shifter in the PARK position (remaining in PARK).
28. Open driver door (remaining open throughout).
29. Depress and hold the brake pedal.
30. Note
Brake pedal application is only required during the first ignition ON then OFF cycle.
Cycle ignition key ON then OFF 5 times, then back to the ON position a 6th time. Keep ignition
key in the ON position for the remainder of the program cycle.
NOTE:
The horn will sound 3 times.
31. Close the driver door.
32. Open the driver door.
33. Close the driver door. The vehicle's horn will sound 1 time to indicate the security enable/disable
option has been accessed.
34. Applying and releasing the brake pedal will toggle the security feature on/off.
⢠The horn will sound once to indicate the security feature is ON.
⢠The horn will sound twice to indicate the security feature is OFF."
