Water leak after topper installed
Pam53
Pam
Dowling mi
2022 ford maverick hybrid lariat
We had an ARE brand cap installed on our 2022 last week. The water is leaking into the bed on both front corners. The water is coming under the moldings on the sides and front of the bed. I'm thinking the solution is to remove the cap and the moldings, install silicone under the moldings and reinstall. I wonder how the factory handles that with a factory cap?
The Weatherman
Dean
KY
There is small channel near the front of the bed on both sides. A small piece of weather stripping cut and installed in those channels can reduce the leaking there.
I noticed it after installing our tonneau covers.
Pam53
Pam
Dowling mi
Can you send a picture?
Joe Kelly
St Charles, Mo
1973 Triumph TR-6, 2009 Accord, 2017 Pacifica
I have the same problem and I went to a third party camper business yesterday and he recommended clear silicone behind the black trim and try a piece of foam in the weld joint. The other issues is the seal bubbles out into the bed. According to him the seal should lay flat toward the rear window. Today I am going to lay a beed of clear caulk under the black trim on the left and right. I don’t want it too thick sow the shell will crush it down. His final statement was manufacturers do not guarantee a water tight fit. The cover is limited protection only. I am going to try but he was not very positive I would be able to seal it 100%. Because of tolerances on the truck.
The Weatherman
Dean
KY
Shay
Sam
Phoenix, AZ
www.youtube.com
2022 Ford Maverick XL Hybrid (sold)
Given the way the truck is designed with the bed and cab attached, sides bordered by multi-piece plastic trims (not water tight), I am not sure how a topper or tonneau cover could ever be truly water tight.
Even if sealed up super good, you will always have water collecting between the rear window and the topper/tonneau with no place to go. There is no drainage path such as on a truck with a separated cargo box.
The Weatherman
Dean
KY
Ford Maverick Water leak after topper installed 800009E6-C520-4C51-9169-6A77A22A4FF0
Ford Maverick Water leak after topper installed 678534C8-FB76-442B-B1EC-FD06BCB2BEF2
This is the type and size of stripping I used. It was put down before the rail was set so that it could be fully compressed and concealed.
Joe Kelly
St Charles, Mo
I put some rubber seal in the weld joint and the gap in the bed cover trim (see pictures). I decided against the silicone calk. I was afraid all I would do is trap the water and cause a bigger problem with rust later on the water that drips in now seems to run out through the drain holes under the bed pad on the floor. I have some gasket material to place on the bed rail and tail gate that I was given to by the camper shell place I visited yesterday. He basically told me no cover is fully water tight. I am going to live with the dribble I have now because it is much better than before. Good luck because some times you just have to live with what it is. I have spent two weeks trying to get leak proof and I give up.
As a note picture two is showing 2 of 12 Maverick XlT’s at the camper shop having shell’s installed. I saw 6 at a ford dealer two weeks ago some one is getting deliveries in the fleet busines. I didn’t think to look if they were hybrids.
Ford Maverick Water leak after topper installed 8E8B3624-1945-4550-AAA2-A68AEBDC2627
Ford Maverick Water leak after topper installed 8B1D711F-603F-4D8C-BE20-6165F247D3AD
PeteSJCA
Pete
San Jose, CA
2025 Maverick Lariat Hybrid AWD Eruption Green
I installed a Truxedo Sentry CT cover yesterday. I doubt it's watertight, but hey it's a truck and it sure looks purdy.
Ford Maverick Water leak after topper installed PXL_20221018_201243237
PeteSJCA
Pete
San Jose, CA
how much and where did you buy it?
I bought it from
TonneauCovered.com
and it was $ 929.99, no sales tax or shipping charge to N. California.
  • 1 x 1594716 - Truxedo Sentry CT - Fits 2022 Ford Maverick 4' 6" Bed for $929.99 each
Subtotal : $929.99 USD
Here's another pic i took today.
A Dodge that drives Fords
Wisconsin
Ford Taurus Ford Ranger
I had quite a bit of water at the beginning right after picked up my Maverick (pictures are one week after picking it up) I loosen the cover from the rails and adjusted it a little better. And now there's hardly any rain in the bed. I also think the Sun helped soften the rubber and helped it lie a little flatter.
Ford Maverick Water leak after topper installed Screenshot_20221018-210717
Ford Maverick Water leak after topper installed Screenshot_20221018-210727
Ford Maverick Water leak after topper installed Screenshot_20221018-210735
Ford Maverick Water leak after topper installed Screenshot_20221018-210744
Ford Maverick Water leak after topper installed Screenshot_20221018-210752
FischAutoTechGarten
Peter
Might be something to get used to.
I'm a bit spoiled with how bone dry the bed of my Nissan Frontier stays with it's ARE topper. No water intrusion at all even during a gully washer (provided I keep all of the windows closed).
