I wonder if Ford reads this stuff? They have to know we are not just making it up.Depending on the tracked charge vs discharge amp hours logged - you may only get 5-10 min of minor charging level, then float charge.
The number of amps discharged after turnoff for the next 60 min because you woke all the modules back up - will be more than battery got charged.
At least 2 posters I saw tried doing that - one at work during lunch time for testing. IIRC it took like 90 min runtime to compensate and end up even. He did let it run all afternoon or morning once for 4 hrs to basically recharge the battery back up to best it would get.
5-10 min of hopefully charging 5A steadily declining to 1A, then the remaining 5-10 min below 1A to 0.5A.
Then 60 min max, of discharging 4A steadily declining to 0.5A for 20 min, then 0.5-0.3 for 20-30 min, then 0.3A for final 10-20 min.
Then it'll drop (or should) to 25-50 mA level.
Each time modules need to go back to sleep - provides an opportunity for a glitch to allow something not to. Now you got a big drain.
I know there must be a reason but why not let the battery fully charge like we used to do?
In rethinking this whole thing. when the truck 'starts' there is no longer the big battery drain to get the starter going-all that it seems to needs to do is to 'make' the circuit and in my case it did not. Now, once it is started I could see the problem when the ICE had to start but not at startup. I am guessing the EV battery was up to snuff but cannot be sure.
Odd, being an oldtimer, that when the charger was put to my truck, there was no 'noise'-the dash just lit up and played the hocus pocus letting me know it was OK to move! Soon after starting, the ICE took over so I assume something decided there was enough battery to start it.
Odd that the EV battery was probably OK but the 12v could not latch on to some of it to get going.
Do you know if there is a sensor that tells the level of battery charge? Heck if they can tell how good the motor oil is,the level of charge should be easy!
I need to find out more details on what type of battery is actually in the truck along with battery case dimensions. I amy be looking at an Optimum for it. Not being able to leave the truck at the airport while on vacation is not a good thing forcing me to use my wife's 2019 vehicle there and that does not bode well for the Maverick.
Thanks for your time.
