USB-A plug under sync console not working
tobymacfreak
Andrew
Hello all!
Recently the USB-A plug under my sync console is not working. Weirdly enough, the USB-C is working fine, and I cannot find any fuses that have been blown.
Things I have already tried:
-Carefully blowing air to clear the port of debris.
-Multiple cords/wires
-Resetting sync
-Checking the Fusebox for issues
P.S. I have a 2022 XLT - EcoBoost
Has anyone else seen this issue?
Don806
Don
SE Ohio
Yep
My 22 hybrid has that issue every once in a while. Last time it was both not working. Dealership wants me to schedule in for them to look at, but it keeps doing it and then both start working again, next day usually, and if it’s working when I take it in, say there’s nothing they can do ☹
mikellmikell
Mikell
Southwest Michigan
2 Colorado's
My 22 was missing a cable to connect it when I first got it. Check with the dealer. lots were missing
NM Bob
Las Cruces, NM
2024 Ford Maverick Lariat
I've had the same issue as Don806. Every now and then when I start my truck the USB-A port does not turn on. I can still connect wirelessly but not connect to my phone using the phone cable. If I turn off the truck and restart everything comes back on... just weird
Toddman45
Todd
St. Louis, MO
Have you guys tried pulling the panel with the USB input to make sure the cable harness is connected properly behind the panel. There is one harness per usb input .
The panel with the USB A & C ports remove easily firmly pulling straight forward.
NM Bob
Las Cruces, NM
No I haven't but that not a bad idea, I';; give it a try and let you know.
riparian
Virginia
2024 Maverick XLT hybrid
Android Auto stopped working 10 minutes into a drive yesterday, and I noticed that neither the USB A or C ports would charge my phone using known good cables. The lights surrounding the ports still glowed. The fuse tested good, and rebooting the infotainment system didn't fix the problem.
I tugged on the port panel as recommended by Toddman45 , and while I didn't pop it out, I did hear a relay click. Sure enough, both ports charge the phone and Android Auto functioned without issue during two hours of driving today.
I'll be pleasantly surprised if this a permanent fix. If it's not, I guess the next step is to snap out the housing that holds the USB panel and 12v power point and check connections. One Reddit post I found reported his dealer service department diagnosing and replacing a bad USB module.
DavidB367
2025 Ford Maverick
Or it's another dreaded head unit software "glitch" :crying:
DrFaustus
Me
San Diego
22 Maverick FWD
In my 22 XL eco,
USB-C charges and connects to android auto.
USB-A charges only.
Happened about 6 months in to ownership.
