- Jul 22, 2021
- Phoenix, AZ
- 2022 Ford Maverick, 2019 VW Atlas
- Engine
- 2.0L EcoBoost
Just installed these CANBUS LEDs from Underground Lighting, originally meant for the current gen F-150, which also uses the WT21W bulbs.
They have switchback and standard amber for up front:
https://undergroundlighting.com/pag...mk_ford~md_f-150~ju_turn-signal-front&limit=9
I replaced all the rear bulbs with this one:
https://undergroundlighting.com/pro...=yr_2021~mk_ford~md_f-150~ju_turn-signal-rear
However, the lights are BRIGHT. Like, hurt to look at in the dark. I'll be on the lookout for less bright LEDs in the future, or possibly a FORScan mod to reduce the brightness, but I couldn't go another day with the crummy incandescents.
The units are all fitted with a mini fan to apparently reduce heat soak and prevent hyperflash, but I'll let you know if I come across any during extended use.
See attached videos for comparison with stock bulbs.
