Under the hood lights on the cheap
Bruce W
Bruce
Brookings, SD
2022 Ford Maverick Hybrid Latiat
Went to The Dollar Store and spent $4 on a couple battery powered 150 lumen lights and mounted them under the hood with some double hook Velcro. Good lighting and no fear of accidentally running the vehicle battery dead. For as seldom as the hood is opened it should last for years, unless I forget to turn them off. May cut into the wiring with an auto tilt switch I found on Amazon but probably won’t bother. AAA batteries are cheap. Will see if they stay on or fall off in a few miles😁
Ford Maverick Under the hood lights on the cheap IMG_8298
Ford Maverick Under the hood lights on the cheap IMG_8296
Ford Maverick Under the hood lights on the cheap IMG_8297
Ford Maverick Under the hood lights on the cheap IMG_8295
upnash
Ohio
Saturn Vue, Dodge Grand Caravan
LED lights are Great!
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
I did something like that in the trunk of a Goldwing I use to own. Got the light at Radio Shack.
jorl
FLORIDA
22 Mav HYB XLT
magnetic rechargeable(usb) flex head flashlight from Harbor Freight-keep in glove box
Bruce W
Bruce
Brookings, SD
Yeah. Not sure leaving light under the hood is really necessary. Figured worth a try for $4. Since they are attached by Velcro can be easily removed and replaced if needed. Have a good magnetic base light but hard to attach to an aluminum hood. 🧐
jorl
FLORIDA
22 Mav HYB XLT
check out HARBOR FREIGHT
BRAUN 300 Lumen Magnetic Pocket Work Light $6.99
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
is this the one you mean?
Ford Maverick Under the hood lights on the cheap IMG_7665
