Turning rear camera on while driving. Anyone?
zakstang
Zak
Rochester, mn
Anyone figure out a way to be able to use the rear facing camera while driving to check trailer load? I would pay good money for the option to be able to use the camera while going down the road to check the trailer load.
hmmmm....
WildHorse
Benny
DE
Dashcam is your money, $200-300 kit is good enough. Remember to get 4K and GPS.
gte105u
Katy, TX
I believe you will need to go after market radio. There are third party ones that can activate the rear camera while driving, but don't think a native Ford option exists. Someone correct me if wrong.
Hillbilly
E. TN.
22 XL
Unless it has changed there Is 1 conductor on the display harness that activates the cam via a positive voltage input. An on/off switch with the correct voltage might getcha what you want. IF it is the same on the Mav
colinl
Colin
ICT
thought about that but id rather use whats there if possible.....
There's not an easy way and it's very easy to use a rear view mirror integrated dashcam. Plus you have a dashcam.
The forscan options for rear view are only useful for older cars that lack a rear camera but other trim levels had it. You could install a camera and enable it. Nothing that would help with this.
zakstang
Zak
Rochester, mn
thanks......hmmmmm
zakstang
Zak
Rochester, mn
is there a rearview integrated dashcam you recommend or have used?? thanks!
zakstang
Zak
Rochester, mn
thanks!
rwthib
Robert
DFW
2024 Maverick Lariat
Anything changes in 2024. Seems crazy to have a camera there that I can't use to take a peak and see how the tow is doing (especially with the towing package!)
