truck bed LED lights installed
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
JUst installed these truck bed led lights:
www.amazon.ca/dp/B0711FYXSM/ref=redir_mobile_desktop?_encoding=UTF8&aaxitk=224e15942f48c0104cddc24f8a9b0012&hsa_cr_id=7973791700601&pd_rd_plhdr=t&pd_rd_r=caf49290-5cbb-4611-bc71-e72c4a301713&pd_rd_w=YR3e9&pd_rd_wg=t33DF&ref_=sbx_be_s_sparkle_mcd_asin_0_title
Had to trim the LED strips down to about 4.3 feet and mounted them to the toneau cover rails. Stock wiring does fit across and the pockets are fully removable for wire routing through the grommets. Used the 12 v power plug on the left side bed. You will need a 10mm socket to remove bolt pocket and T27 torx to remove lower rear anker point (need to remove to get pocket out).
Ford Maverick truck bed LED lights installed interior lightin
Ford Maverick truck bed LED lights installed bed lighting install
BDennis
Bruce
So Cal
Did they plug directly into the 12 volt power plug provided in the bed?
Nighowl2000
Nighowl2000
Roy
Ottawa
Ye but used the plug adapter harness provided with the truck.
Michigan Bill
S.E. Michigan
2023 Maverick XLT Hybrid Lux, 2017 Chevy Equinox
Looks great, Roy! Could you show where you ran your wiring to power both sides? Under the truck, under the front of the bed, etc. Also, did you mount some type of switch, and where? Thanks.
Nighowl2000
Nighowl2000
Roy
Ottawa
See pics: edit... Thought I got a pic of left side... I'll see if I can get one later
Ford Maverick truck bed LED lights installed IMG_20220318_101746258
Ford Maverick truck bed LED lights installed IMG_20220318_101645725
Ford Maverick truck bed LED lights installed IMG_20220318_101626795_HDR
Ford Maverick truck bed LED lights installed IMG_20220318_101619688
Ford Maverick truck bed LED lights installed IMG_20220318_112122611_HDR
Michigan Bill
S.E. Michigan
Thanks for the pics!(y)
BDennis
Bruce
So Cal
Nighowl2000
Nighowl2000
Roy
Ottawa
