So my 2023 ford Maverick xlt isn’t in production yet, but they are saying that I can’t add the tremor package, does anyone know why I can’t add it?
OhBecause order banks for '23s are closed and major changes (to trim or to engine or to limited production models such as Tremor or Black Appearance, for example) were locked at the same time.
Also see:
https://www.mavericktruckclub.com/forum/threads/can’t-convert-‘22-fx4-to-‘23-xlt-tremor.21146/
Not completely right. I added bap after closing to two different orders at two different dealerships.Because order banks for '23s are closed and major changes (to trim or to engine or to limited production models such as Tremor or Black Appearance, for example) were locked at the same time.
In the quest for precision I ought to have said "have since been locked."Not completely right. I added bap after closing two two different orders at two different dealerships.
BAP is different - it's just a package.Not completely right. I added bap after closing two two different orders at two different dealerships.
My point but with more words.BAP is different - it's just a package.
Tremor requires the Advanced 4WD system, not the standard one with FX4. Can't change the powertrain at all - not between Hybrid and EcoBoost, not between FWD, 4WD, Advanced 4WD.
So you should be able to drop FX4 while keeping 4WD. Can't drop FX4 and switch to FWD. Can't switch to hybrid. Can't switch to Tremor's Advanced 4WD, so you can't switch to Tremor.
Might be able to switch between base Tremor and Tremor + Appearance Pkg if you already had one.
Your dealer can tell you the priority code or just ask on Ford chat. The lower the priority the better. The lowest the dealer can go to is 10. If you are a 1 or 2 that means you are being looked at for production and you "can't" make any changes at that point.Yea I just messaged the guy at the dealership and what does priority code mean and how do I found out what mine is?
