Tremor Isssue
DJTremor
Dean
Ford Maverick Tremor
Had a weird freak issue today with my truck. I was driving around for about an hour this morning to run a few errands. On my way home I was going down the road about 40 mph and all of the sudden the vehicle seemed to stall out. I was pressing on the gas and it was just making a noise like it was stuck or something. Pulled over into the break down lane, shut the truck off and started it back up again. Everything was working fine again like normal. I didn't see any warning lights come on the dash either. This is the first issue I've had since I got my truck back in August. Has anyone else experienced this? Seems a little concerning. Please advise
710-oil-614
Cal
2025 Hybrid AWD Lariat
I have not experienced anything like that in 6,600 miles in my Tremor. That would concern me.
RedRider
Kitchener, Ontario, Canada
That could be a bubble of water in bad fuel, or it could be a sign that the pressure sensor for the high pressure fuel rail is faulty. Is the fuel from a reputable high-volume pump dispensing TopTier gas as required by the fuel specs, or is it from an ancient farm stash from a 50gal drum? If it happens again, take it in. It will have thrown a temporary code, but it will only be there until you restarted it. If it is the sensor, then it will eventually throw a permanent code.
DJTremor
Dean
DJTremor
Dean
Thanks, I'll check that out with the pressure sensor. I use top quality gas so it's most likely the sensor
Maverickman74
Shane
Maui HI
Keep us posted. Either way doesn't sound like a Tremor specific issue. Out of curiosity you don't have a tuner or have done anything with the intake? Also worth taking a peek that rodents didn't fill your filter housing with cat food. Seen that a few times.
DJTremor
Dean
I'll keep everyone posted. And no I didn't so anything with the intake.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Do you have a scan tester to review the history? The incident would be recorded. The vehicle may even record a code with out a warning on you instrument cluster. At least you would have some idea of what happened. Have the dealer do it if your not mechanically inclined. And do it soon. You don't want to break down on the road.
DJTremor
Dean
I don't have a scanner. I'll have to take it to the dealership to see if they can find out what happened unfortunately
BBurnie
Bernard
2023 Ford Maverick Tremor
I have not had this issue at 19,500 mi got mine Maverick trimmer in February 2023, please keep us informed
fossil
ernie
ohio
the dealer probably charge you for scan, a parts store will likely do it for free.
Ford Motor Company
Official Ford Account
Dearborn, mi
DJTremor
Dean
The dealership checked it on their end and I also looked on Fordpass app. Says everything is fine. No codes have been detected. I'm hoping it doesn't happen again.
