- First Name
- Jerry
- Jan 15, 2023
- Bergland, MI (U.P.)
- 2022 Maverick Lariat
- Engine
- 2.0L EcoBoost
Earlier this week I got my new travel trailer (about 2,300 lbs), and most everything has gone well, except the trailer brakes. I notice very little if any response from them while driving, even with the gain set at 10. There is a slight response when I use the manual slider, but nothing near what it should be - again, with gain set at 10. I know how trailer brakes are supposed to feel, as I towed a camper (similar weight) frequently for seven camping seasons using three other vehicles.
I came across TSB #SSM 50917 (edit: link MC-10216041-0001.pdf (nhtsa.gov)). My Maverick was manufactured in November 2022, long after the TSB time range. However, I am intrigued by the mention of this settings menu. Can anyone else with 4K tow tell me if this menu is anything other than the gain level adjustment? I am wondering if I'm supposed to have other settings I can change to increase the power that is sent to the trailer brakes. The owner's manual is vague about what is supposed to be shown in the instrument cluster.
Since this is a new trailer, I am aware there could be a brake problem on the trailer. And I already found one - a broken wire at one of the hubs, which I was hoping would fix this issue. Although the re-wiring did stop the "trailer disconnected" error I'd been getting, it had no effect on the braking power once I had the functionality back.
I'm about to the point where I need to pull the trailer drums to see if there is an internal brake problem, but first I want to see if there's anything else obvious that I could be missing. Final note: I had a similar issue with a previous vehicle, with an aftermarket brake controller, and in that case the controller turned out to be defective (was sending proper voltage but not enough current).
Appreciate any suggestions as well as a report on this elusive menu!
