TPS with aftermarket wheels?
Pestpro77
Robert
Long island
Dodge ram
  • Thread starter
  • Banned
  • #1
so the manual says, use tire gauge not TPS…and not for aftermarket tires/wheels
I assume everyone that swapped out the Steelies are withOUT TPS?
I’d rather have flat protection myself
Ford Maverick TPS with aftermarket wheels? B0A43237-AB26-4256-B023-C33A8344C010
Ford Maverick TPS with aftermarket wheels? D0B5A26D-DCFA-4ED0-8A5E-7AD3EE1E0872
Snax
North America
I suspect the part about the sensors not being designed for aftermarket wheels is there to prevent people from using them in random incompatible wheels. As long as you use sensors that are compatible with your wheels, you should be good to go. Whoever installs your tires should be able to figure this out.
Although I drove vehicles before TPMS was mandated, I wouldn't do it again. The old days of only realizing that you had a flat tire when the car started pulling or whomping sucked.
cannon
mark
oregon
2022 Maverick XL awd
Just to avoid confusion, TPS is a throttle position sensor and TPMS is tire pressure monitor sensor. I have aftermarket wheels and my stock TPMS work great.
Maverickman74
Shane
Maui HI
Looks like somebody has been having a little trouble with their TPS reports :coffee:👨‍🏫 were gonna need you go ahead and come in on sunday too, ok, thanks.
kcamp317
Cincinnati, OH
'20 Ford Escape Titanium Hybrid 16 Ford Escape SE
When I swapped the OEM 17s for 19s on my escape they re used the OEM sensors and they work fine.
