TorquePro what are your thoughts on this experienced users.
NJBob
New Jersey
I bought the pro version of Torque. Think it was like 5 bucks. Works very well. I had a scan gauge. Worked well to but it was pricey and is a stand alone device. Good if you want it displayed all the time. Was a pain to find a good spot to put it.
Gullzway
OK
1968 Ford Mustang Fastback
GPSMan
Many
Torque Pro is my go to for OBD apps. I mainly use it when I want to check my Hybrid and 12V Battery Voltage.
I just leave this cheap OBD2 adapter plugged into the truck.
Amazon.com: Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off Check Engine Light Support Android Torque App : Automotive
Whoa that's really cool. Something you can show on the OEM screen?! More details please! Can you see eCVT or motor temperatures? I plan to tow with the hybrid Mav.
Gullzway
OK
I don't see either of those.
GPSMan
Many
How did you get HV battery percent? Or did it just come with it?
How do you get it on the Ford Screen? Is that just cell phone mirroring? I currently have Apple, but I'd get a cheap burner phone just to run apps if there is no equivalent for iOS. Do you have any form of transmission temperature?
GPSMan
Many
What's the highest and lowest you've seen for HV battery percent? What is typical? There should be PID'd for HV battery voltage and temperature. As well as traction motor and generator temperature. I could see all that on the Escape Hybrid, but those PID's don't work for the Mav.
GPSMan
Many
I have a reader only. It is not programming anything. Basically an instrument like a digital volt meter.
I've seen even read-only devices do some funky stuff. One of my scantools has developed an annoying chance of bugging the CANBUS when connected to Fords and causing the instrument cluster, radio, HVAC, etc. to reboot themselves.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
how did you get it to run in android auto? can you share the instructions?
Ive used torque pro for years now. was handy in my jeep wrangler days. those pentastar 3.6's run very hot (205F to 225F till fan kicks on).
Gullzway
OK
Nighowl2000
Roy
Ottawa
Gullzway
OK
