- First Name
- Mark
- Jul 5, 2022
- California, CA
- '09 F-150, '22 Maverick
- Engine
- 2.5L Hybrid
I've wanted to get away from using the LED lowbeams as DRLs since they can't be replaced. I found a hack through the normal Forscan interface to use the turn signal bulb as the DRL instead, but there was also a concern that it could cause pre-mature failure since the turn signal brightness results in excess heat.
I think I finally found the "goldilocks" solution of using the parking lamp as the DRL. It requires a few steps and going through the As-Built Data:
BCM Settings:
Other Things I've Found:
BCM Settings:
- Include Parking Lamp with DRLs
- 11-04: x422-xxxx-x0xx
- 12-02: 422x-xxxx-xxxx
- 10-01: xxxx-xxx*-xxxx
- 0 = Default
- 8 = Police dark car mode Enabled
- 11-04: xxxx-xxxx-x*xx
- 0 = DRL circuit enabled
- 8 = DRL circuit disabled
- 11-04: xxx*-xxxx-xxxx
- 1 = Left turn light: turn + DRL
- 2 = Left turn light: turn only
- 3 = Left turn light: turn + position
- 4 = Left turn light: constant on
- 12-02: *xxx-xxxx-xxxx
- 4 = turns lowbeam off for DRL
- 5 = turns lowbeam on for DRL
- 12-02: xx*x-xxxx-xxxx
