tailgate repair now no lines backup camera
numike
mike
car
2024 Hybrid Lariat
Repair of tailgate
It was removed and re-plugged
Now no back up lines nor no zoom Have the back up beep
Any 'fix' I can do?
Thank You
fossil
ernie
ohio
the camera wires run to the sync head unit, my first move would be a display reboot to reestablish the hand shake.
numike
mike
car
how do I do a display reboot to shake a hand?
Jah.
Jah.
Central Florida
Had that happen to Camry . couldn't figure it out how to get line displays back . then battery needed to be replaced and they reappeared after new battery was hooked up . maybe try disconnecting battery for few minutes and reconnect .
dc73pdsgt
Tucson, AZ
did you check to see the warning lines are turned on on the dash?
numike
mike
car
did you check to see the warning lines are turned on on the dash? how do you do that?
Ozarkbeard
Reboot the Infotainment system and also check Settings there.
To reboot, hold down the Power button and the track skip forward buttons for about 10 seconds or so, until the startup splash screen appears.
CurtisB
2023 Maverick XLT Hybrid
From what I saw somewhere in this large and ever expanding MaverickTruckClub forum universe, someone mentioned that there is a very small connector underneath and near the spare tire area that MUST be connected in order for the rear camera to work. The poster said he took off his tail gate to modify something and upon reinstallation, forgot to connect this small connector. Perhaps this is your situation?
numike
mike
car
ty I will look into it
Silver23
Ya not going to be the camera connection, if it was that there would be no picture.
settings and/or reboot.
avane
Alvin
Toronto, Canada
2011 Impreza 5-dr
@numike did you fix this? Same issue with me..tailgate got fixed and now camera doesn’t show backup guidelines
