Super Bug Guts or Bad Windshield?
scharris99
Daytona Beach
2025 Maverick XLT
Wax your windshield when you wax your car. Much easier than Rain-X & works the same. Also, when you notice your windshield needs to be re-waxed, so does the rest of your car.
MikeS1942
Windsor Ontario
24 Maverick Lariat
I've noticed that too - even after attacking a couple worse spots with moist napkin area, just doesn't want to come off.
Gas station washer always worked fine on prior Rav4.
Same seasons for my long drives - so not different bug guts.
But perhaps they are eating different things.
Which now that I say it - maybe I don't want to leave problematic bug guts on headlight plastic surfaces for too long.
Wet a fabreeze cloth, and wet your windshield. Wash the windshield with the wet fabreeze and it will melt the bugs away. Rinse off right away. It will also work on paint without harming---just make sure you rinse it off right away.
cyberdog
Ray
2023 Maverick Lariat Hybrid
Sealing the windshield really helps make them more removable the next time. Once it's clean, use RainX, Glaco, Aquapel, or whatever your glass sealer/repellant of choice. - RainX is likely the cheapest per application of the bunch, however you'll need to re-apply it more frequently.
When you buy washer fluid, they green one removes bugs more readily than the Blue or Pink/Orange mixes when using the wipers. For the more difficult splats, some isopropyl alcohol on a microfiber cloth does wonders. (You can also use it painted surfaces, the dealer suggested it for tree sap many years ago).
Escapologist
Niagara Region, ON
In Southern Ontario, we seem to have had a bug comeback, last decade it has been very light in spring bugs. This spring, got a layer of "bug butter" on the front of the car that seems more like it was in the noughts. Though also in our 2025 Escape, the Ford Factory fill of windshield washer seems particularly pathetic at washing anything off the screen. Then last few times I've been at gas stations they didn't have suds, just plain water in the windshield squeegee things so that didn't help either.
Edit: Colors of the screen wash here. There is a pink that is a specific summer bug wash type, works well when it's fresh. It "goes off" somehow after maybe a year, so don't buy too much. Also needs flushing before frosts because it freezes. The blue is basically "doesn't freeze water" meaning they just stick enough methanol in to keep it from freezing down to -40, but beware of cheap stuff that might be low conc and not do so well. Yeah the green is methanol plus some form of cleaner/detergent and for winter gets your salt streaks gone more easily. Then there's a purple winter which is a more heavy duty de-icer and yellow which is that plus rainX. Anyway, not sure which is the bad pink, unless it's just a generic summer pink water with no detergent.
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
As I drive to/from my daughter's house 2 hours away, I've noticed when I get back I have a lot of bug guts on my windshield. That's nothing new, but I've also noticed that they hang around forever! The 2 pictures below show a bunch of specks on my windshield from a drive I took two weeks ago (not all the specks are from that drive). Since then, I've run it through the car wash, used the windshield cleaner thing at 2 gas stations, and we've had multiple good rains while I was driving 30 minutes to/from work.
How is ANYTHING left on the windshield after that much effort (by me AND nature) to clean it all off? Whatever is in those bug guts needs to be harnessed and used for making some kind of epoxy glue or adhesive! OR is there something with how windshields are made now? Less smooth? More "sticky" to foreign substances? This wasn't a problem with my '22 Maverick. I've just noticed it this Spring, and I got my '25 Maverick in January. Anyone else experience this?
In just about any auto parts store you can find a special sponge encased with a plastic-like "net" that is especially made for removing bug splatter form paint and glass. I have always used these when washing my vehicles with excellent results.
For bug spots between washings I use bug & tar remover.
Here in Florida "love bug" season has started. These acidic bugs will eat the paint if left on, so at the end of the day the vehicle has to be inspected and bug splatter removed. Best to keep the front end well waxed or some other paint protection.
MikeS1942
Windsor Ontario
24 Maverick Lariat
The problem with the plastic netting is it does scratch the paint. If you're OK with that then not a worry. They are great on glass though. The fabric softener cloths are the best and scratch free, because the chemicals in them soften and dissolve the bug remains.
elliptic
elliptic
Ford Maverick XLT
I figured out the "solution" on a road trip last year.
Baby wipes. I had the costco ones on hand.
One pass with one wipe, a second cleanup pass with the second wipe - it will be a bit streaky.
Just wet it with washer fluid/wiper for 2 swipes and everything will be clean and good as new! I've never found anything that works better.
Buggy Man
Summerfield Fl
If you have a good coat of wax on the vehicle you won't have a problem with the "bug remover pad" but you have to use something for lubrication not just the pad by itself. Like soap suds. If you just use the pad alone you are picking up any dirt that is in the area and scratching the paint. Typically I would remove the bugs while washing the vehicle, otherwise I use the bug and tar remover and a micro fiber cloth - lots of different brands out there.
I have used these for more years than I'd like to say. Have never had any scratches.
ClemsonU88
ClemsonU88
NC
No, just make sure it is 4-0000 four-ot, search some videos online and you will see. Do it dry as well. I’ve been doing it for years, I learned from a detailer
Thanks.
