Street Race Dual Tip Exhaust Installation
MRTperformance
Plymouth,MI
www.ShopMRT.com
Required Tools
Sawzall
18mm Socket
Suggested Additional Tools to help make the job a little easier
Trim /Clip Removal Tool
Exhaust Hanger Removal Tool
WD-40/Lubricant to soak the rubber exhaust isolators for easy exhaust removal
Installation generally takes 25-40 minutes
Non dual tip systems install exactly the same. For single tip systems you will skip the two steps of passenger side hanger installation and passenger tail pipe placement.
Step up the "Fun Factor" of your 2.0L Ford Maverick pickup with a customized premium exhaust system handcrafted in the USA. MRT exhaust systems give your versatile small pickup an aftermarket MRT exhaust that elevates the sound presence, improves the performance and helps your Maverick produce the right sound, with the right presentation for an exciting driving experience. Plus - you replace the factory turn down tips with polished chrome or black matte 3.5" beveled edge tips to dress things up a bit.
In stock and ready to ship!
www.ShopMRT.com
Mabcim
Rochester, NY
Finally, “dual“ exhaust. Nice!
Do you have more sound clips?
How much does it interfere with the spare tire?
Wonder if there was a reason for picking that tip separation, versus going wider?
MRTperformance
MRTperformance
Plymouth,MI
www.ShopMRT.com
First video is interior/exterior sound clips
Second Video is a ride along with our head engineer
This system does fit with the spare. As for the tip presentation, our engineering team felt like a super wide dual tip presentation did not aesthetically pleasing. We also wanted to reuse the factory exhaust hanger locations as well.
Mabcim
Rochester, NY
Thanks for the reply. Nice sound.
Zed79
Zed
UP
22 XL AWD
Does not allow the removal of full sized spare. My exhaust was shipped 5/2024 had to add an 15mm deep socket to tire tools needed so If need be I can loosen the drivers tailpipe. Wish they had moved the tips out more to address this. sound 5/5 fit 2/5 would also like to see the front mount used its a small bit a steel would make installation easier as well as take some load off that flex pipe at the front.
