- First Name
- Gator
- Apr 10, 2025
- Bend Oregon
- 2025 Maverick Lobo, 2020 Edge ST
- Engine
- 2.0L EcoBoost
Have you tried to figure out what brake pads and rotors fit a 2025 Lobo? I want to do full track sessions in the HPDE/Club/SCCA Track Nights type formats and knowing that the OEM pads would not cut it for more than a couple of laps I'd need to upgrade the pads. I didn't want full race pads/rotors that have to be swapped around every time you head for the track, already been there with a C6 Z06. And if I was going to actually race I'd be swapping out for AP Racing/Wilwood/Brembo/Alcon BBKs anyway. So performance pads that would work for HPDE, AutoX, and are still street capable were the target.
All of us Lobo owners probably know the Lobo is supposed to have the front brakes from a Euro Ford Focus ST. But what year? Little did I realize the rabbit hole I was about to go down. I quickly discovered that no US auto parts stores have the slightest clue what pads fit on a 2025 Lobo. They either say they don't have anything at all, or they say to use the same pads that go on all the other Mavericks. We know that since we have 2 piston front calipers and all the other Maverick models have single piston calipers that isn't going to work. And the official Ford Parts website is just as bad. Even putting your VIN in the search box brings back a confusing array of pads and rotors including the correct and the wrong OEM pads (and wrong rotors).
After many hours of research including contacting USA and UK brake pad manufactures directly here's what I've figured out:
The front pads that fit the Euro Ford Focus MK4 ST 2019-2022 are the ones that fit our Lobo.
Also OEM Ford BRF1908 are correct for the 2025 Lobo (w/enhanced brakes) and 2021-2025 Lincoln Corsair Grand Touring. Interesting that Lobo brake engineers chose a pad material from the Lincoln parts bin for a Lincoln hybrid. That tells me they were maximizing quiet and low dust over performance.
Note: The Euro Focus ST added a "Track Pack" option in 2022 that has 4 piston Brembo front brakes. The standard 2022 Focus ST still used the 2 piston calipers. The 2024 Focus ST comes standard with Brembo 4 pots.
The Key to the mystery is the Lobo uses FMSI pad size D1818. This FMSI number is referenced by different manufacturers as 9053D1818 and D1818. Don't know what the FMSI pad size means? I'll leave it to your favorite AI search tool to explain.
Knowing the FMSI pad size opens up an entire world of brake pad options.
FMSI Pad Size D1818 is 193mm Long x 65mm Wide x 18mm Thick +/- a few tenths of a mm in length and width, and a wider range in pad thickness. To verify I pulled the OEM pads off my Lobo, those were the measurements.
What other vehicles use FMSI pad D1818?
2019-2022 Euro Focus ST; 2015-2020 Ford Edge, 2017-2018 Ford Fusion, 2016-2019 Lincoln MKX, 2019-2023 Lincoln Nautilus, 2021-2025 Lincoln Corsair Grand Touring.
Performance Pads. Although there are many brands of OEM replacement pads for the D1818, there are very few track capable choices. Here's what I found:
EBC UK:
Front: Euro Ford Focus MK4 ST 2019-2022
EBC Yellowstuff DP42383R 193.0mm x 64.8mm x 16.5mm eBay $200 + Int'l shipping.
EBC Bluestuff DP52383NDX 193.0mm x 64.8mm x 16.5mm eBay $210 + Int'l shipping.
I purchased the Bluestuff DP52383NDX from a UK eBay retailer. It took them almost a month to clear customs and arrive. I can verify they are the correct size. My micrometer says they are actually a little over 17mm thick.
EBC USA:
I contacted EBC USA about the 2025 Lobo. They said to use:
EBC DP43046R Yellowstuff on the front. 193.3mm x 65mm x 18.5mm on pad 1, 193.3mm x 65mm x 17.8mm on pad 2. Available at Summit Racing and other suppliers in the US.
Rear Pads: EBC Yellowstuff DP42160R. FMSI D1665 Pad 1 123.2 x 55 x 15mm; Pad 2 123.2 x 49 x 15mm
I haven't personally verified these fit yet but I'm confidant they will work.
Porterfield:
Front: R4-S AP1818. https://porterfield-brakes.com/product/ap1818/
FORD: 15-18 Edge AWD, 19-20 Edge FWD, 17-20 Fusion AWD Gas, 2025 Maverick HD Brakes // LINCOLN: 17-20 Continental, 22-25 Corsair Hybrid, 16-18 MKX, 17-20 MKZ 3.0L, 19-20 Nautilus
My Take: Higher performance street pads, good for autox and very light track use. Better than OEM but not as good on the track as the above EBC pads.
About EBC Pads:
EBC Bluestuff: Highest-performing road-legal material
20% longer life than YellowStuff
Faster Bed in Speed than Yellowstuff
Friction = 0.45 Temp range = 0-625°C
Bluestuff is the spec pad for Euro BMW Cup races.
EBC Yellowstuff: Flagship fast road and light track material
Progressive braking with excellent pedal feel
Friction = 0.42 Temp range = 0-500°C
Rotors: I measured our 2025 Lobo Front rotors: Diameter 330 mm x 27.2 mm thick by 51 mm height. Same as Euro Ford Focus Mk4 ST 2019-2025.
OEM Part, "enhanced brakes" SZ6Z1125A aka BRRF-1989. *See note below.
EBC D2180, GD2180, USR2180. For performance driving you want the GD2180
New Maximum Disc Thickness: 27mm
Minimum Disc Thickness: 25mm
Disc Height: 51mm
Disc Diameter: 330mm
Number of Holes: 5
Disc Style: Vented
Weight: 20kg
Fitment Position: Front
*Probably the same size as OEM Ford BRRF-1989 but not confirmed. BRRF-1989 are OEM listed to fit only the 2025 Maverick with enhanced brakes. Or Disc Brake Rotor - Ford (SZ6Z-1125-A) 2025 Ford Maverick - sz6z1125a. I have not purchased these rotors so I can't verify yet.*
EBC Brake Rotor Range Explained: EBC Brake Rotor Range
Installation Note> The Lobo Front caliper sliding pins have a 11mm hex. The standard Maverick are 7mm. The Lobo Rear pins are 7mm, just like standard Maverick.
My plan: I'll get a baseline track day at Oregon Raceway Park with the truck 99% OEM. The only mod I've made is the Ford Performance exhaust. Everything else will be as delivered.
Then I'll go back for 2nd day with the front EBC Bluestuff pads. No other changes., including stock suspension settings. I've found after years of racing that if you make 2 or more changes you will never be sure which change made the most impact.
We'll see how the ABS copes with the EBC Bluestuff front pads and OEM rear pads. I may have to put Yellowstuff pads on the rear. No plans on swapping for performance rotors yet.
EBC UK:
EBC USA:
Porterfield:
About EBC Pads:
Disc Height: 51mm
Number of Holes: 5
Disc Style: Vented
Weight: 20kg
