Some rotating sort vibration at stop / park
Greendesert
Rits
Pittsburgh
Elantra GT '14, 2022 CRV Hybrid, 2025 Maverick Hybrid Lariat
My truck does not even have 1 k mile and I feel some rotating vibration with v faint sound when ICE is on. Drives butter smooth.
Could it be the shaft going back in AWD?
bgn
WA
The driveshaft is disconnected at idle and when AWD is off. Might be a motor/transmission mount or many other things.
Is this just on startup in Park, and after a bit (warmup?) it goes away?
Or remains in Drive when stopped even after warmup driving?
Actually, for ICE to be running when stopped - is it that cold still?
Or you think running for the recharging of HVB?
The cold temp/initial start of Generator motor running at RPM to cancel out ICE RPM so virtually in Neutral, for some does cause some bucking/shaking while the computer sorts things out.
Others ended up having a bad damper between ICE and tranny.
And at least 1 thread the OP fixed that with some good hard accelerations.
Greendesert
Greendesert
Rits
Pittsburgh
I was also thinking on the lines that it only happens when cold. Will check and let know, thanks
Shelbyv8
JD
Maverick XL, Grand Caravan, 2002 Ranger xlt
Turn your music on and enjoy life.
Greendesert
Greendesert
Rits
Pittsburgh
Well, at 980 miles, I got AWD powertrain error twice today.
Damn Ford, you are getting good at it!
