jcast0311
South Texas
2023 Ford Maverick Lariat 2.0 EB LUX FX4 4K CG
It's almost like you jailbroke your car and you need a factory reset.
No. I did all the steps that the ford update page told me to do.
I tried master reset … the car auto shuts off before it can complete the reset and it’s really annoying.
BlackBeard
Dennis
Memphis
2023 Maverick XLT
jcast0311
South Texas
Only works for the US App Store FordPass app according to the developer
As a follow up to 2/8/22 thread https://www.mavericktruckclub.com/f...ck-diy-how-to-instructions.10056/#post-785687
Yesterday, I saw a reddit thread that the Siri shortcuts were working again on iPhones and Apple watches.
Functions include:
Start my Car
Turn off my Car
Lock my Car
Unlock my Car
Whats my Car Odometer?
Whats my Cars Oil Life?
Wheres my Car?
I purged the old versions I had used and installed the new shortcuts following the reddit thread. I entered my FordPass email address, FordPass password, and VIN number in during the installation of the first shortcut. After installing all the shortcuts, I manually activated the Start my Car shortcut (pushed the tile) and granted permission to run and voila... Maverick started. Followed up with Turn off my Car which also worked.
Will test verbally later today.
Cheers!
Bryon
(Only works for the US AppStore ford pass app)
Install all of these, Make sure you install the first 4 in order. also the first shortcut is critical as you have to insert your login details and VIN number correctly for it to work.
Fordpass Settings https://www.icloud.com/shortcuts/fde6cc1200434ffdae2ffd16aeb297a3
Get fordpass token https://www.icloud.com/shortcuts/00059a7fbda349cd8ae166d2863b8752
Get Autonomic token https://www.icloud.com/shortcuts/08cbca80d4e641d3bb01dd67dda57955
Execute Command https://www.icloud.com/shortcuts/1b707a69ad3c4579b3d8728e9cbcbcd3
Start my Car https://www.icloud.com/shortcuts/71c5c519ca064668974692e8a5914b95
Turn off my Car https://www.icloud.com/shortcuts/e7c32ced47a04114b2e97a650ca74c33
Lock my Car https://www.icloud.com/shortcuts/487da05b29e7451e8a2234abe7c3ea28
Unlock my Car https://www.icloud.com/shortcuts/ce48e9fedc6e481cbd543cbb1c47ca53
Whats my Car Odometer https://www.icloud.com/shortcuts/0037f6b7bc884e66bd35325000b50d55
Whats my cars oil life? https://www.icloud.com/shortcuts/f8639ae0bcc841048f24ebde9a27db82
Wheres my car? https://www.icloud.com/shortcuts/08212976c3634db29930961a36975602
I finally got the new update on my Mac and ford pass works.
Is there a way to change Km to miles??
BlackBeard
Dennis
Memphis
2023 Maverick XLT
It worked for me except for Siri. “I can’t help with that.” When I ask her.
Have to make sure you have the first 4 shortcuts, have run them, and then run this one with a press before asking Siri to do it.
jcast0311
South Texas
I closed the app. Went to Walmart and tried it. It worked!
jcast0311
South Texas
Functions include:
Start my Car
Turn off my Car
Lock my Car
Unlock my Car
Wheres my Car?
Cheers!
Bryon
Got it all working perfectly now. Here’s a view of my Maverick iPhone wall screen. Thanks! No more using FordPass app.
Ford Maverick Siri Shortcuts for Start / Stop / Unlock / Lock & More Commands Work! IMG_0998
BlackBeard
Dennis
Memphis
2023 Maverick XLT
Nice! I got a bit carried away.
Ford Maverick Siri Shortcuts for Start / Stop / Unlock / Lock & More Commands Work! IMG_0793
BlackBeard
Dennis
Memphis
2023 Maverick XLT
I was trying to do the same but I didn’t know how to change it the duo one.
Apple doesn’t make it easy. Have to delete the ones you don’t want then add the dual ones. They should let you have more control, mod the ones you have, etc.
jcast0311
South Texas
Cool while it lasted. Just today it just stopped.
TRUCKHEF
SOCAL
22' Ford Maverick XLT
Same. Mine is no longer working either.
Mjasi3
Chicago usa
Bronco
Functions include:
Start my Car
Turn off my Car
Lock my Car
Unlock my Car
Wheres my Car?
Cheers!
Bryon
So I was able to get this working. iOS 17.5.1 fordpass 5.
I tried these from this Reddit post (https://www.reddit.com/r/shortcuts/s/z0bgbN2t9g) but couldn’t get them to work. They are missing the execute command. But they have commands for: is my vehicle locked, zone lighting, range, etc.
Can those other commands be implemented using the setup in the ones here?
For instance here is “their” “is it locked” shortcut. How do I change the one from maverick to work?
Ford Maverick Siri Shortcuts for Start / Stop / Unlock / Lock & More Commands Work! IMG_7934
Mjasi3
Chicago usa
Bronco
ok, had this all working. all commands (and through SIRI) and received all notifications back. Upgraded to IOS 18. and the commands are broken. Siri doesnt recognize them, and none of the states work. if I manually go to the shortcut and press unlock/lock (haven't tried turn on/off yet) they work. Any body else have this problem with ios18 and troubleshooting?
Ford Maverick Siri Shortcuts for Start / Stop / Unlock / Lock & More Commands Work! IMG_0234
Mjasi3
Chicago usa
Bronco
ok. got it working. just in case somebody else has issues.
turned off shortcuts in systems preferences/iCloud. restarted iPhone. turned on shortcuts in system preferences. this got the notifications/status shortcuts working. But not the lock, unlock, start, stop with Siri.
I then deleted the lock, unlocked, start, stop shortcuts, and re-imported them from this link (which I think is the same as before):.
Siri now recognizes the shortcuts.
