Seeking LED Lighting Switch Trigger Wire Input
Rogueshot
2025 Ford Maverick XL Hybrid
Good day, all!
LED lighting, gang switch, and wiring topic here.
I’ve installed three sets of LED lights on my 2025 XL hybrid truck. I have one set pointing backwards. This set has a white DRL and then a white flood light option.
I installed an M&R 8-gang switch in the engine compartment which also has the ability to trigger a light set to automatically turn on with a certain vehicle operation. I want to tap a wire, hopefully, within the engine compartment to trigger my DRL. Then a separate wire tap to trigger the backup/reverse lights.
Thus my two questions:
1. Any suggestions on which wire to tap for the DRL in the engine compartment?
Follow-up - DMAT gave me the suggestion to tap the blue wire on the headlight.
2. Any suggestions on which wire to tap for the backup lights in the engine compartment? I want to avoid running a wire back to the taillights.
Follow-up - DMAT suggested running a wire to the tailights, but let me know if there are any other options/ideas.
Many thanks for your time! I'll post some updates once I have this all looking and operating as I want it.
Rogueshot
Rogueshot
Ford Maverick Seeking LED Lighting Switch Trigger Wire Input 1000007903
Mavster Mechanic
Hybrid
Interesting.
So not just a power/fuse block but also relays?
We never had those as kids.
BlueSpec1
Gene
Maverick - 2025 TT Backup Lamp Relay BJB -> F58(#69) 10A -> C1035A Pin 18 -> Gray/Brown -> C222 Pin 29 -> C404 Pin 38 -> C401 Pin 6 -> C4099 Pin 7 TT Connector
