Having lived in a solar powered home for 50 years, here are a couple thoughts. $400-500 will buy a Honda clone "suitcase style" generator that will run for hours on a single gas fill. If needed, a deep cycle battery and charger, plus small inverter will allow you to run low wattage loads like a modem and laptop in between charges. The truck to the left has a single panel on the roof that will run a 12 v (compressor type) refrigerator when it is not plugged into the 12V Mav bed outlet. Using your truck to run an inverter for extended periods, IMHO, is using a steam engine locomotive to pull a little red wagon.
