Running antenna cables from the cab to the bed.
wb5oxq
Waco Texas
2023 Maverick Lariat in Alto Blue
I will be installing 2 different 2 way radio antennas on each side of the bed. I want to know if there is a way to get cables from inside the cab into the bed area without drilling holes? Ham radio, CB radio etc.
bgn
WA
This is what I used for my GMRS antenna cable. Very convenient design from Ford.
wb5oxq
wb5oxq
Waco Texas
I wonder if the cables will fit below the door edge trim or try to fit them below the carpet at the edge of the door.
wb5oxq
wb5oxq
Waco Texas
I think I found an even better spot to run my cable. In the upper corner on each side of the bed there is a small opening more than big enough for a coax cable to pass through. The factory sealed these openings with some kind of foam. I believe it will come out just below the window in the corner. I just need to see where. I have not managed to remove the trim panel below the rear speaker on each side yet. I pushed the end of a whip into the opening and it went in at least 6 inches so it should be in there somewhere.
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
Any further progress with the little holes in the upper corners of the bed to get into the cab please? Thanks!
