Running RCAs From ACM to Rear
nobbyv
The NH
'24 EB Maverick XLT, '22 Porsche GT4 & Macan S
I have some speaker-to-low level converters I'll be using to tap the front speaker wires coming from the ACM. The have female RCAs on the other side, so I'll then need to run an RCA cable from there to my amp in the back. Thought I read that most people snaked RCAs from the ACM to the rear through the center console area. But I'm not sure how to hide them in the space where the console ends and the rear seat begins. Under the carpet? Or did I misread and most people are actually running them down the side?
EDIT: Nevermind, ended up just running it down the pass side with the remote turn on wire.
MilleGrs
Michelle
United States
2024 Ford Maverick
I used an rca cable adapter behind the ACM to tap into the rear speaker signals without cutting any factory wires. It worked great for sending a clean signal to my amp. Just be sure to double-check the polarity and use some zip ties to keep everything secure behind the trim panels—it gets tight back there.
