Recall changes 24S24/24V267
lavaspill
Jeff
Has anyone had the recall and able to see in Forscan what the changes are? Did they just up the charging from 80%?
Packer Bill
South Dakota
I had both 24S24 and 24S27 recalls done recently. I originally had my charge level changed to 95% by using ForScan. After the recall, the charge level reverted back to 80% so I once again changed it to 95% again.
lavaspill
Jeff
Thanks! Wonder what they changed.
Robar
Rob
'22 XL EB 4K AWD
I just had 24S24 done on a 22 4k AWD and they didn't seem to touch most of the BCM. When I got 24S27 done I lost all my BCM related FORSCAN changes for cruise control.
NZ6T-14F390-ADD (BCM) only seems to affect the 12V alternator output detection failsafes built into the BCM. N1PA-12A650-AE (PCM/ECU) is an general alternator output increase. Coincidentally the PCM update coincides with a PCM strategy code update from NZ6A-14C204-HD to NZ6A-14C204-HE on my ecoboost.
I heard that some hybrid owners are on the x-HF version of the strategy code after the recall was frozen during its first two weeks of rollout (back when it was x-HE, which lead to some limp mode issues). Curious if any ecoboost owners are on this revision or if this was solely a hybrid/specific MY thing.
SPLMAVERICK
Alexander
2022 Ford Maverick XL 2020 Hyundai Elantra
Well my 12 volt battery is dead. Next Monday the mobil reprogram technician will be in town. Reading other articles it is sughested to have a well charged battery? Well my is dead so I'll have to try to fix that in the a.m.. then proceed from there.
Packer Bill
South Dakota
I would recommend buying an AGM battery (non-Ford). I bought my battery at Costco for $170 a few months ago. Ford will give you another junk battery for replacement. I also changed the charge level to 95% with ForScan. No issues for a few months now! (I have a 22 Mav EcoBoost).
SPLMAVERICK
Alexander
Good to hear. Ford covered it under the 3/36 warranty. Now I wait till Monday for the recall work to be done at my home.
