Rear Light Brackets
enjoitheride
OH
2025 Lariat Hybrid AWD
Hey, Guys. Does anyone make light brackets to add lights to the rear of the truck? I usually add an amber dual light facing rearward for bad weather, or just visibility when backing up camping. Not sure if there’s a clean mount option. I am not interested in one that uses the hitch receiver.
Thank you!
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
For the purpose of illuminating to the rear of my Maverick, especially for when hooking up my PWC trailer at night, I added a 3” LED pod hanging below each corner of the bumper. They are secured using OEM screws found at those locations. I have a switch mounted on the bed cubby door or can use a remote I keep in the center console to turn them off and on.
Thank you!
Ford Maverick Rear Light Brackets IMG_1883
Ford Maverick Rear Light Brackets IMG_1697
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
This plugs right into the trailer plug and does not make the guidelines in the rearview cam disappear. I had to mount below my bumper on a 1 1/2" alum.angle bar . For it will not fit properly under tailgate
Visit the Store, ONLINE LED STORE
ONLINE LED STORE
Visit the Store
4.3
4.3 out of 5 stars
(824)
True Mods 49" LED Tailgate Light Bar + Signal Relay Box [Ford F-150 F-250 F-350 Super-Duty up to 2018] [Sequential Turn Signal] [Tail & Reverse Light] for Ford Pick-Up Trucks with Tow Package & BLIS.
This description will get you to Amazon's light I bought
enjoitheride
enjoitheride
OH
ONLINE LED STORE
Visit the Store
4.3
4.3 out of 5 stars
(824)
Thank you for the info!
enjoitheride
enjoitheride
OH
This is what it looks like below bumper
nice! And, it doesn’t take away too much ground clearance like a cube/ ditch light style light would.
Hybrid25XLTAWD
WA
25 XLT AWD Maverick Hybrid (ordered)
Diode Dynamics makes a mounting bracket for under the bumper
DrEvil
Stephen
24 awd turbo maverick
Nice clean install on the blue truck. If you don't.
Want to go to Is cutting the bumper andont want the pepboys bracket look. Here is a less than one hour installed. Very bright flood in the camera view.
Ford Maverick Rear Light Brackets 20250104_100009
Ford Maverick Rear Light Brackets 20250104_095735
DrEvil
Stephen
14 in of 1.5 by 1x8 flat stock . Used 7 in 10$ light bar. Drilled 2 holes to use existing rear number mount screws .2 holes for light bar. Painted flat stock black. 30 min. Used wire tap to trailer wiring reverse wire. 1 wire 18 inches to existing ground screw. 15 minutes. Tremendous difference in light mounted low in camera view compared to high mounted reverse lights.
DrEvil
Stephen
Also look at my installed front light bar .dual color amber/white. Way more light than the bumper installed cutout lights. We compared both trucks side by side at my buddies off road shop. And 1/4 the price.
DrEvil
Stephen
I don't see any reason to.
Be a smart-ass. I didn't say anything to be disrespectful to you. All I commented on was the light output. In fact I commented that it was a very nice install.
DrEvil
Stephen
I checked out their website.I see no s a e j 593. Licensing of these backup lights. I do see s a e environmental test. Is waterproofing. What you must be referring to. By reading comprehension is strong.I am an attorney.
